Hey chaps,
I'm currently restoring a Mudblaster and am in need of the electrics. I intend to get this thing filthy so I'll be needing waterproof everything.
What I'm asking for is recommendations for the esc and servo, I'm not looking to spend a crazy amount but I'm not really 100% sure what is best for bashing about with. I am thinking a balloon will be fine for the receiver as I have a Flysky handset ready to go.
Any help is very much appreciated.
Shane
I will second the Hobbywing Quicrun 1060, excellent no fuss and cheap esc, servo wise the obvious choice would be a traxxas unit like fitted to most of there ready to run Rc's, but ive had a look around as you don't need anything too heavy duty.
http://www.modelsport.co.uk/alturn-usa-standard-deluxe-ball-bearing-waterproof-servo/rc-car-products/371888
http://www.modelsport.co.uk/etronix-es092-digital-std-waterproof-metal-geared-servo/rc-car-products/378613
unless your planning on running under water, im not sure i would bother with waterproof, maybe smear a little grease round the joints etc, ive never managed to kill one yet in the wet.
other waterproof options are from hobbyking, ive used there servo's for years and there good value.
http://hobbyking.com/hobbyking/store/__28972__H_King_High_Torque_Metal_Geared_Ball_Bearing_Waterproof_Servo_58g_12_8kg_cm_0_22s_60.html
http://hobbyking.com/hobbyking/store/__28971__H_King_High_Torque_Waterproof_Analog_Servo_40g_4_5kg_cm_0_13s_60.html
the specs of the 1060
Specification:
  • Fwd. Cont. / Peak Current - 60A /360A
  • Rev. Cont. / Peak Current - 30A /180A
  • Input - 2-3S Lipo or 5-9 NiMH
  • BEC Output - 2A/5V (Linear Mode)
  • Motor Limit - 2S Lipo or 6 NiMH - 540 or 550 Size Motor: 12T or RPM 30000 - 7.2V
  • 3S Lipo or 9 NiMH - 540 or 550 Size Motor: 18T or RPM 20000 - 7.2V
