Scapelnz 204 Posted November 20, 2014 Hey team Ive just picked up a trf201 and was after some info on what hex adapters and size to get. Would love some advice before I buy the wrong ones Also does anyone know what different shells if any fit the 201 chassis? Thanks in advance Share this post Link to post Share on other sites
Sayer 742 Posted November 20, 2014 On the Hexes, 12mm probably (and welcome!) Share this post Link to post Share on other sites
JeepnMike 150 Posted November 20, 2014 Does anybody make 12mm hexes for the TRF201? I have been trying to find ways to convert my DB01 to 12mm hexes and it has been a bit of a challenge. I think the TRF201 is in the same boat. Share this post Link to post Share on other sites
Origineelreclamebord 45 Posted November 20, 2014 If you're looking to use parts that you can bolt on straight away, search through the Tamiya sub-forum on oOple - I recall some TRF503 users are using 12mm hexes on their cars - if it works on those cars it will work on the TRF201, too. As a home-brewn solution, I Wild Willy (wide) hexes that I had cut down in width slightly (and I recall the hole drilled up to 5mm) - I only used them occasionally (as my most commonly used tires were on pin-type wheels), but they still lasted me 2 years. One of them stripped when a nyloc wheel nut loosened, if that hadn't happened, it would still be happily running these hexes today Share this post Link to post Share on other sites
Origineelreclamebord 45 Posted November 30, 2014 Just a small update: I just saw a sale on oOple of Tamiya 12mm clamp hexes for the TRF503 (it should also work with your TRF201) - the part number is #9804801 1 Share this post Link to post Share on other sites
GregM 1109 Posted December 1, 2014 For shells: Sand Viper and Zahhak bodies should fit. Share this post Link to post Share on other sites
