zomboided 374 Posted December 11, 2014 Hard body (beetle shell), I'm guessing car body paint, plus some labels. What have people been successful using in this situation? Oven cleaner (and what kind, UK brand), de-solv-it graffiti remover, brake fluid (which DOT?). Given the cost of a new shell, I'm wondering if it's worth the bother, so I'm looking for something that'll just cause the paint to peel off easily rather than me spending hours sanding! Share this post Link to post Share on other sites
TamTom 367 Posted December 11, 2014 Tiger Entfetter works great. I am using for over twelve years now. Harmless to plastic and lexane bodies. You even can keep decals on lexane bodies for getting paint off the inside. You can even soak bodies or parts for weeks or even months. http://www.obi.at/decom/product/Entfetter_1_l/1686609 1 Share this post Link to post Share on other sites
yogi-bear 2321 Posted December 11, 2014 I have been using either dettol (although expensive, needs to be the antiseptic not the hand cleaner) or oven cleaner (Easy Off Bam, very cheap, but has to contain sodium hydroxide). Dettol just smells, otherwise its pretty harmless to skin with minor contact. With oven cleaner, make sure you ventilate well. I tried brake fluid and found it dried the plastic out, so have avoided that since. Brake fluid success will also depend on the DOT type. Success from each method can depend on the paint type. Finally post pics of what you try please! 1 Share this post Link to post Share on other sites
SteveU30 1011 Posted December 11, 2014 Desolvit all day long, will have it back to bare plastic in half an hour max (3x 10 minute sessions back to back). Link to buy from Screwfix: http://www.screwfix.com/p/de-solv-it-graffiti-remover-1ltr/45293?cm_sp=Search-_-SearchRec-_-Area1&_requestid=285871 Jonny Retro's excellent guide: http://tamiyabase.com/blog/painting/145-paint-stripping.html 4 Share this post Link to post Share on other sites
zomboided 374 Posted December 11, 2014 Finally post pics of what you try please! ALWAYS! Thanks for the replies gents, I'll give the graffiti removal stuff a go. Share this post Link to post Share on other sites
camy67 13 Posted December 11, 2014 Caustic soda worked for me, on a hard beetle shell that had acrylic,polycarb and auto paint on it.....for twenty years. Share this post Link to post Share on other sites
bromvw 744 Posted December 11, 2014 Desolvit all day long, will have it back to bare plastic in half an hour max (3x 10 minute sessions back to back). Link to buy from Screwfix: http://www.screwfix.com/p/de-solv-it-graffiti-remover-1ltr/45293?cm_sp=Search-_-SearchRec-_-Area1&_requestid=285871 Jonny Retro's excellent guide: http://tamiyabase.com/blog/painting/145-paint-stripping.html That Desolvit is great - it shifts anything with out harming the plastic . Local bus company use it on their shelters all the time . this stuff is also great for removing decals http://www.ebay.co.uk/itm/like/351054901644?clk_rvr_id=747013081010&crlp=1_262531&mt_id=635&sdc_id=1418342039z774232z4c073b0a14249z&mid=424487&fitem=351054901644&linkin_id=8076831&crdt=0&sortbid=20 1 Share this post Link to post Share on other sites
sparkysx 125 Posted December 12, 2014 Did you win that green one on evilbay then? Share this post Link to post Share on other sites
derv_scaler 17 Posted December 12, 2014 Bead blasting works perfectly and doesn't damage the shell itself at all, not really a DIY option for most but you can usually find someone locally who can do it quite cheaply. Share this post Link to post Share on other sites
sparkysx 125 Posted December 12, 2014 I suppose it depends on what media you use and the pressure? Share this post Link to post Share on other sites
derv_scaler 17 Posted December 12, 2014 I used glass beads at 115 psi (hence bead blasting) steel shot would wreck the body. I think soda blasting would work well too, so if you have access to a compressor you can make a soda blaster from an air duster nozzle and some PVC tubing. Share this post Link to post Share on other sites
Fruitfly01 596 Posted December 14, 2014 A +1 for the Desolvit. SteveU30 pointed me to it a little while ago when i wanted to strip a Jugg body. It did in minutes what brake fluid took weeks to do. I was chuffed to bits. Share this post Link to post Share on other sites
Kevin_Mc 411 Posted December 14, 2014 I collected used dot 4 brake fluid from my mate's garage and it stripped the paint off my clod body in big soft flakes without and harm to the plastic. I'd use it again and again, but i obviously get it for freeso it may not be the cheapest option for everyone Share this post Link to post Share on other sites
zomboided 374 Posted December 15, 2014 Did you win that green one on evilbay then? No, but I did win a rather nice dark grey one, with box :-) You guys using de-solv it, I'm gonna go pick some of this stuff up tonight. How are you applying, just on a cloth all over the body, or some sort of soaking for a period of time? What's the approach here? Share this post Link to post Share on other sites
SteveU30 1011 Posted December 15, 2014 No, but I did win a rather nice dark grey one, with box :-) You guys using de-solv it, I'm gonna go pick some of this stuff up tonight. How are you applying, just on a cloth all over the body, or some sort of soaking for a period of time? What's the approach here? Have a look at the link I posted above to Jonny Retros guide, I followed that with excellent results. 1 Share this post Link to post Share on other sites
Fruitfly01 596 Posted December 15, 2014 Heck, I didn't even know there was a guide I just poured a good dollop on the body and then went to town with a toothbrush - which is what Jonny Retro seems to have done too. Don't forget the gloves or you'll be covered in paint by the end of it all. From this to this to this Share this post Link to post Share on other sites
SteveU30 1011 Posted December 15, 2014 To be honest that's about as much of a guide as you need, it really is that easy to work with isn't it? 1 Share this post Link to post Share on other sites
bromvw 744 Posted December 15, 2014 To be honest that's about as much of a guide as you need, it really is that easy to work with isn't it? like that old advert - it does what it says on the tin lol 1 Share this post Link to post Share on other sites
Fruitfly01 596 Posted December 15, 2014 To be honest that's about as much of a guide as you need, it really is that easy to work with isn't it? Totally. And thanks for telling me about it too. 1 Share this post Link to post Share on other sites
SteveU30 1011 Posted December 15, 2014 That Desolvit is great - it shifts anything with out harming the plastic . Local bus company use it on their shelters all the time .  this stuff is also great  for removing decals  http://www.ebay.co.uk/itm/like/351054901644?clk_rvr_id=747013081010&crlp=1_262531&mt_id=635&sdc_id=1418342039z774232z4c073b0a14249z&mid=424487&fitem=351054901644&linkin_id=8076831&crdt=0&sortbid=20 Do you just put this stuff straight on the decal then? 1 Share this post Link to post Share on other sites
berman 5315 Posted December 15, 2014 Watching this thread with interest as I have two bodies that will need to be stripped. I have de solv it, but i have this strange feeling that the stuff we and the Aussies get might be different to your 'graffiti remover' version Share this post Link to post Share on other sites
SteveU30 1011 Posted December 15, 2014 Watching this thread with interest as I have two bodies that will need to be stripped. I have de solv it, but i have this strange feeling that the stuff we and the Aussies get might be different to your 'graffiti remover' version Here's the safety data sheet for the UK one, might be worth comparing with the one you can get? http://www.desolvit.co.uk/userfiles/file/Graffiti%20Remover.pdf 1 Share this post Link to post Share on other sites
zomboided 374 Posted December 15, 2014 I was expecting you guys to tell me all to shut up and use search Top advice, links and pictures, thanks all. Share this post Link to post Share on other sites
yogi-bear 2321 Posted December 16, 2014 Watching this thread with interest as I have two bodies that will need to be stripped. I have de solv it, but i have this strange feeling that the stuff we and the Aussies get might be different to your 'graffiti remover' version yeah, we don't get the same stuff, which is why I use either dettol or easy off bam. Share this post Link to post Share on other sites
SteveU30 1011 Posted December 16, 2014 I was expecting you guys to tell me all to shut up and use search Top advice, links and pictures, thanks all. That's why I love this forum, the 'use search' phrase is as good as banned in these parts! Definition of a forum: "An assembly, meeting place, television program, etc., for the discussion of questions of public interest." 1 Share this post Link to post Share on other sites
