I have three of these in various models and find reverse very frustrating - sometimes it works and sometimes it doesn't - am I alone in finding this? With the auto-setup there is not much you can do :(
Only running silver cans and Sport Tuneds through them...
Man that's a pity. So auto-setup isn't really that helpful, is it? I think manual setup along with double-tap reverse makes me keeping my Tamiya ESCs for brushed motors.
For a basher I wouldnt care but I use two in my M-Chassis racers and the last thing you need on track is reverse not to work when you are in a race!
Cheers everyone - there is hope then! Will give them a thorough testing on Sunday at A1 - albeit in different vehicles...
Maybe your throttle channel is reversed or something? I just setup my first 1060esc and it dropped in and ran perfectly with no adjustment. I am on a Spektrum dx4c.
Zero problems with any of mine so far. I have a about five of these in various cars running with HK3100 receivers. The only time I thought one didn't work was down to user error - I hadn't set ATL to 100% on the transmitter (Core RC Code).
Good luck fixing your issue.
Oh, so it's auto sensing
According to the manual
- the usual "leave your tx to defaults"
- when you turn it on, leave the trigger in neutral for 3 seconds and wait for beep, to allow it to calibrate
- check if when returning to neutral, led goes off
Also, I think after calibration the first command should be forward and not reverse
