sparkysx 125 Posted January 10, 2015 I have to say I had no problems what so ever I was charged just over £6.00 for that little lot. This was my first order though. Just as an aside what I do is have the Code for my runners but have a couple of period Accoms Techniplus Txs for the shelfers or ones that wan't to stay original. My recipe for collecting as a general rule is Re-res for runners originals for display or if re-res are not available two originals but the runner version gets the modern control gear ESC etc. Takes all the hassle out of choosing for my very small brian Took the plunge and ordered a couple of these from hobbyking! also ordered the core 2.4ghz stick set from modelsport. 3 Share this post Link to post Share on other sites
wood5tock 864 Posted January 10, 2015 Took the plunge and ordered a couple of these from hobbyking! also ordered the core 2.4ghz stick set from modelsport. Share this post Link to post Share on other sites
BigSteve 149 Posted January 10, 2015 Will those rx's work with the Etronix pro tx's. I think I read somewhere that Code and Etronix were basically the same units. Steve. Share this post Link to post Share on other sites
sparkysx 125 Posted January 11, 2015 They should do, I've been told they are identical with different names on them. Share this post Link to post Share on other sites
BigSteve 149 Posted January 11, 2015 Cheers for that info. I'll order a couple of rx's from hobbyking' s UK warehouse when they are back in stock. Steve. Share this post Link to post Share on other sites
BigSteve 149 Posted January 22, 2015 So I bought two HK3100 rx's from Hobbyking's UK warehouse to use with my Etronix Pro steering wheel TO as I believe they are the same as Core RC's TX's. I tested them on my test rig that contains an esc, servo, motor and a 7.2V stick pack. The first one worked perfectly with no issues great. The second one started ok but then the servo was slow to react to the steering wheel on my TX. Then it would unbind and then rebind by itself. Anyway the latter has been sent back to the UK warehouse under warranty and hopefully it will be replaced. But I have to say Wow they are so compact compared to the Core and Etronix rx's and just a little over £11 delivered each which took just two days and a third of the price of the Core and Etronix versions. Will definitely be buying more. Steve. 1 Share this post Link to post Share on other sites
sparkysx 125 Posted January 22, 2015 I still haven't got mine yet! Share this post Link to post Share on other sites
Nobbi1977 1793 Posted January 22, 2015 I ordered three from the UK warehouse a couple of days ago. I will test them all to make sure they are ok Share this post Link to post Share on other sites
Fruitfly01 596 Posted January 22, 2015 If you ordered through the international warehouse you might be waiting a while for parts to arrive. I waited almost a month for parts to arrive. I wasn't happy. Sometimes it's just quicker to back order something through the UK warehouse. Of course if the UK warehouse has the bits you want, you'll normally wait less than a week. Share this post Link to post Share on other sites
BigSteve 149 Posted January 22, 2015 If you ordered through the international warehouse you might be waiting a while for parts to arrive. I waited almost a month for parts to arrive. I wasn't happy. Sometimes it's just quicker to back order something through the UK warehouse. Of course if the UK warehouse has the bits you want, you'll normally wait less than a week. I ordered the both of them last Thursday evening from the UK warehouse (normal first class post 98p) and my postie delivered them on the Saturday morning. These are really small rx's and must surely be the best value for money rx's around. Their returns system on their website is awesome and you can track the progress of your RMA claim on line to. It also gives you the ability to print a returns label as well. Steve. Share this post Link to post Share on other sites
Fruitfly01 596 Posted January 22, 2015 I have several of them in various cars. I think I have eight bound to my Core handset, so room for more, and there will be Small isn't the word If you're new to this set up, coming from old 27MHz systems with BEC, don't forget that this Rx doesn't have a BEC, so make sure you fit one or that your ESC is equipped with BEC circuitry. 1 Share this post Link to post Share on other sites
sparkysx 125 Posted January 22, 2015 I'll give them 30 days max, then I'll be onto paypal to get a refund! Share this post Link to post Share on other sites
BigSteve 149 Posted January 22, 2015 I have several of them in various cars. I think I have eight bound to my Core handset, so room for more, and there will be Small isn't the word If you're new to this set up, coming from old 27MHz systems with BEC, don't forget that this Rx doesn't have a BEC, so make sure you fit one or that your ESC is equipped with BEC circuitry. My test rig uses an etronix probe plus esc I'll have to check. My runners are fitted with either tamiya 105 BK esc ' s or hobbywing quicrun 1060 esc ' s. I though all modern rx's and/or esc ' s had BEC built in. Steve. Share this post Link to post Share on other sites
Nobbi1977 1793 Posted January 22, 2015 I have several of them in various cars. I think I have eight bound to my Core handset, so room for more, and there will be Small isn't the word If you're new to this set up, coming from old 27MHz systems with BEC, don't forget that this Rx doesn't have a BEC, so make sure you fit one or that your ESC is equipped with BEC circuitry. I am wondering if I can house one of these and the ESC inside a small project box to waterproof them. An alloy one would be a good heat sink for the esc Share this post Link to post Share on other sites
Fruitfly01 596 Posted January 23, 2015 My test rig uses an etronix probe plus esc I'll have to check. My runners are fitted with either tamiya 105 BK esc ' s or hobbywing quicrun 1060 esc ' s. I though all modern rx's and/or esc ' s had BEC built in. Steve. The 105BK and 1060 ESC's both have BEC circuits so will work fine with the HK3100 Rx and any other Rx you choose. Like I say, most ESC's are fitted with BEC and almost any large Rx (often beginner types) are fitted too. Not always the case, and the more professional you go, the less likely you'll find integrated components as it is assumed that an experienced user will want to fit their choice of equipment than be 'stuck' with what the manufacturer decides. Share this post Link to post Share on other sites
Fruitfly01 596 Posted January 23, 2015 I am wondering if I can house one of these and the ESC inside a small project box to waterproof them. An alloy one would be a good heat sink for the esc I would personally avoid holding the radio equipment in metal boxes, mostly to avoid interference or short circuits. Technically speaking, non conductive alloys should be okay, look at the RC10 buggy and most nitro buggies that use alloy pan chassis and what not. As for the ESC needing such a large heatsink... If that's the case, I would be looking at my gearing, motor and terrain in order to find a solution to keep the ESC cooler. The ESC's fitted heatsink and/or fan should be all it needs. Share this post Link to post Share on other sites
DaveB 151 Posted January 23, 2015 Core RC, Etronix and Tamco are all the same unit. I ended up buying the Tamco as it was around £15 cheaper at the time (though the name and logo aren't as cool as the Core RC). Its been faultless for me and I've run Tamco, Core and two different Hobby King receivers on the TX without issue. Share this post Link to post Share on other sites
Nobbi1977 1793 Posted January 24, 2015 I would personally avoid holding the radio equipment in metal boxes, mostly to avoid interference or short circuits. Technically speaking, non conductive alloys should be okay, look at the RC10 buggy and most nitro buggies that use alloy pan chassis and what not. As for the ESC needing such a large heatsink... If that's the case, I would be looking at my gearing, motor and terrain in order to find a solution to keep the ESC cooler. The ESC's fitted heatsink and/or fan should be all it needs. I was thinking of keeping cool if housed in a waterproof box with no airflow. Interference would not be an issue if the aerial is on the outside and short circuits just need a gromett to avoid Share this post Link to post Share on other sites
sparkysx 125 Posted January 31, 2015 raaarrrghhh! these still haven't arrived! Share this post Link to post Share on other sites
wood5tock 864 Posted February 1, 2015 raaarrrghhh! these still haven't arrived! The 3100s? did you order them through the UK warehouse? Ordered mine from the UK on the 25th and they arrived on the 30th. Share this post Link to post Share on other sites
Nobbi1977 1793 Posted February 1, 2015 The 3100s? did you order them through the UK warehouse? Ordered mine from the UK on the 25th and they arrived on the 30th. Mine were about the same time from the UK warehouse, it might be worth sending them an email. Share this post Link to post Share on other sites
sparkysx 125 Posted February 1, 2015 Nope, I ordered mine from HK before you ordered yours. They don't respond to the live chat and when they do they just copy and paste answers, so will give it a few more days then phone Paypal. Share this post Link to post Share on other sites
wood5tock 864 Posted February 1, 2015 Nope, I ordered mine from HK before you ordered yours. They don't respond to the live chat and when they do they just copy and paste answers, so will give it a few more days then phone Paypal. That sucks, have you tried live chat with the UK warehouse rather than the global one. The chap I spoke to regarding some questions I had was a little pre rehearsed if you know what I mean but still helpful. Sorry for the delay mate, it's rubbish waiting on stuff and then not being able to at least talk to someone properly about it... Share this post Link to post Share on other sites
Terz1 745 Posted February 1, 2015 Hope they come soon sparky. There's nothing worse than waiting and waiting for things to arrive. I'll be getting some of these receivers too eventually. I've just ordered a code 2.4ghz transmitter from modelsport. I really like stick transmitters and needed to replace my old radio gear. Always been impressed with their customer service and delivery times. 1 Share this post Link to post Share on other sites
Sandster 285 Posted February 1, 2015 I know it not nice waiting but it has only been 3 weeks since you ordered. It is quite common to wait 4 weeks or even more for stuff to arrive form HK. 1 Share this post Link to post Share on other sites
