yellowcat 117 Posted January 18, 2015 Here is my template for the SRB Dual Rear Shock Mount. Just like my Butterfly Chassis, it is 1/1 scale in pdf file. Here is the Drop box link to my template artwork. When you open the link, if the create an account appears, you don't have to create an account. Just X it out and click download again and save in pdf file. Dual Rear Shock Mount template HERE Please select actual size in Adobe Reader when printing. The printed artwork rectangle is 5" X 7". Please use a ruler to measure the rectangle if it is exactly 5" X 7". This is to confirm the accuracy of your printer. If it is exactly 5" X 7" then the Shock mount template will be 1:1 scale. You need to pick up some 0.05 inch thick aluminum sheet (I prefer 0.064). The upper mounting tap is bended/folded to 90 degree at an angle. You need to bend one for the left and one for the right. So that both should be perpendicular straight when mounted onto the roll bar and the swing arm. If the tab is not quite 90 degrees after the bend, you can adjust by twisting the tab a bit. This shock mount is for the stock long front shocks. It is not for the rear short shock. This also may or may not work on the stock plastic body shell. Fabricate a pair over the weekend.Template mounted and cut out of a piece of .064 inch aluminum.Comparison between the aftermarket and the one that I finished. The aftermarket one is the thin one which is .0428 inch thick.Shock mount mounted on a Rough Rider roll bar.Dual shocks mounted and it works. 4 1 Share this post Link to post Share on other sites
Crash Cramer 617 Posted January 18, 2015 Wow, they look so identical to one another, it is hard to tell which is which. It looks great to me and I think the work was well worth it as your version looks like it will stand up to more use?? Thanks for posting this. Share this post Link to post Share on other sites
mongoose1983 3335 Posted January 18, 2015 Excellent stuff! Share this post Link to post Share on other sites
Cooltoys 129 Posted January 18, 2015 Awesome work & nice of you to share them to the Tamiya fans :-) Share this post Link to post Share on other sites
oz-trash-cowboy 63 Posted January 19, 2015 Very nice work. Share this post Link to post Share on other sites
njmlondon 570 Posted January 21, 2015 Very nice work. Many thanks for the template. Will need to source suitable material. Can I ask if you have tried it. Does the aluminium hold up to much abuse? Share this post Link to post Share on other sites
yellowcat 117 Posted January 21, 2015 Thank you for all your comments! If I have more time, the next template will be a SRB sway bar and rear mono shock unit. Very nice work. Many thanks for the template. Will need to source suitable material. Can I ask if you have tried it. Does the aluminium hold up to much abuse? The thin one is an after market item and it was popular during the early eighties with no problem. RCH had a similar item but it was for short rear shocks only and not for coil over. I just beef up mine with a thicker piece of aluminum which I finished last weekend and I haven't got a chance to try it yet. You can also cut it out of a steel plate. Here is a link to my Ford F150 with an updated design for bigger long single shock. http://www.tamiyaclub.com/forum/index.php?showtopic=74924 1 Share this post Link to post Share on other sites
mclarke 0 Posted September 30, 2020 Hello to anyone out there... I'd really like to get my hands on a set of dual shock mounts for the Tamiya Sand Scorcher. If any of you have a set you'd like to sell, please drop me a line: montage303@yahoo.com (Matthew) Share this post Link to post Share on other sites
