I used tamiya acrylic pots airbrushed on the inside of my Dt-02 and after my first bash the edges are starting to chip off. I used relatively thick coats, about the same as I would use on the outside of a vintage motorbike.
What have I done wrong? Wrong paint, process or does just flake of easily?
All advice welcome but I want to avoid spray tins. Limited colours and half leftovers littering the place to not appeal to me and the price if prohibitively high.
Lexan needs flexible paint otherwise it will chip off. Even then I've seen polycarbonate paint flake off - the trick is to apply many thin coats and let each one cure fully.
Hi
You need to use polycarbonate paint on clear bodies. Other paints will chip off as the body flexes.
I thought the Tamiya acrylic was the correct stuff, what range should I be using?
I have quite a few jars of Tamiya brush paint for polycarbonate if you don't like spray paint - what colour do you need ?
Let me know & I can check if I have some to spare.
Thanks for the offer, what range of paint should I aim for? Think I am using the X- ones
Tamiya paint for polycarbonate in jars is the PC range, polycarbonate spray paints are the PS range.
Guess I better order some new stuff then. Never trust LHS for advice
Ah well, at least you have some paint handy should you want to paint and weather a hardbody. The acrylic paints work well for those, adhering nicely and giving an aged, used-looking non-gloss patina.
they also work well enough to add the window rubbers on the outside of lexan shells as i found out quite accidentally a few days ago .
Yes, they are also very handy at detailing the cockpits on the F1 bodies too :)
James
I will use them to paint my Willy's so not a huge issue.
If the lexan is prepared properly, the paint can last a long time, somethimes longer than the lexan, ( depending on skill / nerves of the driver ). I have polycarbonate bodies 20+ years old that are still holding the paint ok.
Nothing to add, but same here. My Vanquish/Avante/Egress hybrid is 20+, with no cracks.
I received a few pots of Tamiya PC paint today so I might get time to spray over the weekend
ideal weekend to do it - forecast is for warm and dry weather .
All the more reason to venture off into the garage and paint..... That's when I get the really tough stuff done... Vigorous scrubbing of stubborn parts, lots of hammering and screaming at the top of my lungs.....sorry did I go too far... I thought it was all in my head...oops
