quote:Originally posted by Shodog
...heard the TXT uses 6mm UJ's
id="quote">id="quote">
Shim them with tubing from the K&S rack.
(need to look for the metric K&S though, lot harder than the imperial)
Tower Hobbies looks good, but I am in the UK.
What metal is the Jugg uj made of?
Do the srb ones get worn because there is no diff? I know on 1:1 cars locked diffs can break halfshafts easily.
I wouldn't go through all that trouble when the original Brass Uj's are still available at Tower Hobbies. http://www2.towerhobbies.com/cgi-bin/wti00...=1&I=LXGE52&P=7
Very true. [:D]
Unless one's bought the wrong ones already and own a tiny little
K&S tubecutter, then its only a quick 5 min job. [|)]
(Most time spent drilling the hole for the grubscrew.)
Find a set of steel super champ ones they are much better.
Although they do come at a slightly more expensive price.
Really expensive, I mean you'd be mad to shell out that much money
for some UJ'S, I KNOW LUV BUT I REALLY NEEDED THEM!(women hey they just don't understand)
Hi,
You can still order the Brass UJ's direct from Tamiya UK (THE HOBBY COMPANY LIMITED 01525-385-798) all you need is the part number (and some money).
Dave
You might want to try 01908 605686 for The Hobby Co, they recently moved premises and this is their new number!!
But even if you ring the old(01525 385798) number a nice recorded message tells you about the number change!!
No, they wear because they are made of brass, which is really too soft. Thats why the SC ones are steel
