chickenman242tk 266 Posted April 14, 2015 Im in the final phase of my bl blitzer build and need a set of rear tires that can cope with a 5700kv motor ,i have a set of stockies for shelf duty but need something decent like maybe a proline tire or something, any ideas Share this post Link to post Share on other sites
Gruntfuggly 562 Posted April 14, 2015 I use an old pair of Schumacher Vee-4s on mine - I'd get some more if I could find somewhere selling them... Share this post Link to post Share on other sites
Thommo 1201 Posted April 14, 2015 Proline Dirt Hawgs glued very very well... Share this post Link to post Share on other sites
Backlash 481 Posted April 14, 2015 What surface(s) are you driving on? Share this post Link to post Share on other sites
bromvw 743 Posted April 14, 2015 Proline Dirt Hawgs glued very very well... I'll second that - great all surface tires Share this post Link to post Share on other sites
wolfdogstinkus 1876 Posted April 14, 2015 proline dirt works are good. Share this post Link to post Share on other sites
bromvw 743 Posted April 14, 2015 proline dirt works are good. in terms of lasting how would you say they compare to the Dirt Dawg's ? Share this post Link to post Share on other sites
wolfdogstinkus 1876 Posted April 14, 2015 I had dirt hawgs and they didn't last long at all. I haven't worn out the Dirt works yet. Share this post Link to post Share on other sites
chickenman242tk 266 Posted April 14, 2015 it will probably get used on a oval near by and on a bit of clay from time to time. the rears are 2.2 ?? Share this post Link to post Share on other sites
bromvw 743 Posted April 14, 2015 it will probably get used on a oval near by and on a bit of clay from time to time. the rears are 2.2 ?? yes rears are 2.2 . Proline Dirt works would work well on a oval and clay . http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUM92 they will also fit the front's BTW . However i've found these to be excellent on the front end http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDX57&P=M Share this post Link to post Share on other sites
XV Pilot 1936 Posted April 15, 2015 Anyone know of a set of low-profile tarmac-oriented tyres that would fit the rear wheels? Share this post Link to post Share on other sites
wolfdogstinkus 1876 Posted April 15, 2015 Proline road rage are pretty good. Share this post Link to post Share on other sites
chickenman242tk 266 Posted April 15, 2015 I may also try a race style tire while im at it , just waiting to put a big tire order in may a pair of m2 calibers for something with a lower profile Share this post Link to post Share on other sites
berman 5315 Posted April 16, 2015 There is two versions of the 2.2 Dirt Hawg, 1 and 2. Most people are refering to the 2, (#1070-00) as it has bigger spacing between the lugs but also has a higher sidewall, I think from memory it is taller than the stock blitzer tyre. Take this into account when running a 5700kv. You only have two gearing options so I would highly recommend using a temp gun with that combo as I would imagine it would be on the hot side. And video, a video is a must Share this post Link to post Share on other sites
topforcein 1764 Posted April 17, 2015 Proline road rage are pretty good. I second that I run mine on traxxas wheels. A tight fit but looks good also. Share this post Link to post Share on other sites
wolfdogstinkus 1876 Posted April 17, 2015 Blitzer on 4600kv,,, don't remember if this was 2s or 3s but it is a bit of a handful.. I do often use it with 3s,,, well I did until I broke it again.. Checked the text,, it's 3s lipo. Meant to say,, it is sitting on Proline dirt works all round.. Share this post Link to post Share on other sites
