Hi all I have a beat up mad bull runner that's fitted with a sport's tuned motor, full bearings and cva shocks. My question is would it be ok to run with 2s Lipos.
Steve.
Indeed. The Mad Bull gearbox is extremely tough, and can take a lot of power, so the extra voltage from a LiPo won't hurt it. Just run a steel pinion and keep the wheel nuts tight so the hex splines don't wear, and all will be well.
I'm running my Mad Bull with a 3500v Brushless and 2S Lipos. With a steel pinion no issues at all, if you find a Lipo that fits
I'm running my Mad Bull on brushless and LiPo too. Tough buggy. One issue is finding a LiPo that fits the battery compartment, there's a whole thread dedicated for Tamiya chassis lipo compatibility in the all things electric section.
There are also some threads of brushless/lipo equipped Mad Bulls in the general section along with more helpful advice.
Edit: Since you aim to run your Mad Bull with a brushed motor, please keep in mind that the gearing of the DT-01 chassis is mainly designed for buggy wheels. With larger wheels and rough terrain, inefficient brushed motors will produce a lot of heat, even more when being fed with the slightly higher voltage of a 2s Lipo and stressed from longer runtimes.
540 brushless or larger than 540-sized brushed motors are able to overcome the poor gearing due to having more torque and better efficiency.
Typically, the lower the motor's turns, the higher it revs, but the less torque it has.
With a car like the Mad Bull, with big tyres and limited gearing, you don't really want to be sacrificing torque.
You could of course put standard-size buggy wheels on it, which would shorten your rollout and allow fitment of a more rev-centric motor.
Personally I think the Mad Bull looks great that way, and I think Tamiya should have released it as a Grasshopper III.
That really looks cool are they standard 2WD DT02 wheels that you fitted.
Can anyone recommend a 2s lipo that fits the mad bull without any modifications needed.
Steve.
The Yuki Brainergy 4000 is great - but you need to import one from Germany. I paid £24 on ebay
Indeed. The white ones are from a DT-02 Fighter Buggy RX, and the chrome ones are the Carson DT-01/02 set.
The buggy front wheels will not go straight on a Mad Bull. They would need spacers, since the stub axles are too long.
Or you can replace the front steering knuckles to stock DT-01/02/03 items.
