drcarlos 57 Posted May 11, 2015 Are there any options for different springs for the Egress without resorting to swapping the hi cap dampers? After spending some time trying to set up my Egress for running at the local track I find that the car is over sprung so I'm after something a bit softer, the springs on my Cougar SV2 are too large at the top and too small at the bottom. Was thinking about looking at the ones on the Hobao H2 we have but my suspicion is that they will be too big top and bottom. I have problem with the car trying to roll too and have dialed back the servo EPA to about 65% both ways but I'd like to get a bit more action (up to 75%) without inducing a roll over and I think the springs are the next stage. Carl. Share this post Link to post Share on other sites
kontemax 1725 Posted May 11, 2015 Losi springs work well. Max Share this post Link to post Share on other sites
Backlash 481 Posted May 11, 2015 I was going to suggest Team Associated springs, but they are a bit smaller diameter than Losi springs, so maybe they wont fit..? http://www.teamassociated.com/parts/details/1582/ http://www.teamassociated.com/parts/details/1581/ Share this post Link to post Share on other sites
drcarlos 57 Posted May 11, 2015 Losi springs work well. Max TLR22? If yes that's fantastic news as I have a spare set from my boy's H2 Pro (it's a TLR22 clone basically) and can also borrow the blue and yellows that were recommended for the H2 on Astro, so I can try before I have to buy another set. Thanks. Share this post Link to post Share on other sites
kontemax 1725 Posted May 11, 2015 I don't know if modern Losi's springs have different diameters but the springs until 2006/2007 for sure will work. I used them on my Hi Cap dampers on Egress, Top Force and Dyna Blaster. Max Share this post Link to post Share on other sites
drcarlos 57 Posted May 11, 2015 I don't know if modern Losi's springs have different diameters but the springs until 2006/2007 for sure will work. I used them on my Hi Cap dampers on Egress, Top Force and Dyna Blaster. Max Thanks I'll try the Losi springs I have at home and the Hyper H2 ones too and see how they go. If not I'll look at the others you mention. Share this post Link to post Share on other sites
redzone 212 Posted May 12, 2015 Vintage ones not big bores will fit Share this post Link to post Share on other sites
EastWolfDownUnder 33 Posted September 19, 2021 On 5/11/2015 at 11:58 PM, drcarlos said: Are there any options for different springs for the Egress without resorting to swapping the hi cap dampers? After spending some time trying to set up my Egress for running at the local track I find that the car is over sprung so I'm after something a bit softer, the springs on my Cougar SV2 are too large at the top and too small at the bottom. Was thinking about looking at the ones on the Hobao H2 we have but my suspicion is that they will be too big top and bottom. I have problem with the car trying to roll too and have dialed back the servo EPA to about 65% both ways but I'd like to get a bit more action (up to 75%) without inducing a roll over and I think the springs are the next stage. Carl. Hi Carl, Did you ever get a good solution to the above Egress shock issue? I'm here in 2021 lockdown searching for a solution. Want to make the ride height lower and still have travel like a AE B74.1 Share this post Link to post Share on other sites
