Guest Carsnboats
Hi,
I have a question regarding TA03 chassis. I am aware that there are front and rear motor versions and different length chassis' but if I wanted to convert one to a TA03-S which versions could I use as a donor?
Clive[:D]id="Comic Sans MS">id="size3">
Interesting idea, the twin motor version, I must try that. Yep, either front or rear is possible, any TA-03 standard car would be suitable as a doner, but if using the short chassis, make sure you use the shorter belt......... which should be with you tomorrow by the way[;)]
