Jason1145 3986 Posted September 13, 2017 Thanks I'm waiting for a running video from you to show it off! I can't wait to get it out on the road and test it out, thanks to your thread I just learnt how to adjust the ride height at the rear by using those different parts the rear axle runs through... Any idea how to raise the front ride height? Share this post Link to post Share on other sites
Badcrumble 4203 Posted September 13, 2017 23 minutes ago, Jason1145 said: I can't wait to get it out on the road But not with that gorgeous (and rare?) shell??!! 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted September 13, 2017 1 hour ago, Jason1145 said: Any idea how to raise the front ride height? Three ideas; none of them are particularly easy or great: - Mill out 1 mm pockets in the FRP chassis plate so F2 and T4 sit a little lower in the chassis plate. - Mill off material from the bottom of F2 and T4 so the whole assembly sits closer to the chassis plate. - Remove material from the bottom of each steering knuckle; add the same amount of spacers between the suspension springs and the lower C-clips. Maybe do all three to get the best effect? On the other hand, you might get the most ride height change just working with F2 and T4. 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted September 13, 2017 1 hour ago, Badcrumble said: But not with that gorgeous (and rare?) shell??!! I agree with you! I wouldn't risk scuffing that Advan Courage shell except in a gentle test run. I'd put something else on the F103GT for regular running. Share this post Link to post Share on other sites
Jason1145 3986 Posted September 14, 2017 19 hours ago, speedy_w_beans said: Three ideas; none of them are particularly easy or great: - Mill out 1 mm pockets in the FRP chassis plate so F2 and T4 sit a little lower in the chassis plate. - Mill off material from the bottom of F2 and T4 so the whole assembly sits closer to the chassis plate. - Remove material from the bottom of each steering knuckle; add the same amount of spacers between the suspension springs and the lower C-clips. Maybe do all three to get the best effect? On the other hand, you might get the most ride height change just working with F2 and T4. Let me get a look at the chassis again and familiarise myself with those part numbers and try to visualise those effects ;p Thanks Share this post Link to post Share on other sites
Jason1145 3986 Posted September 14, 2017 Post correction Share this post Link to post Share on other sites
DaveBuildsRC 210 Posted September 18, 2017 On 2017-06-18 at 3:27 PM, Jason1145 said: and then this on the front? https://www.3racing-parts.com/tamiya-f103gt-chassis-aluminium-2mm-offset-12mm-wheel-adaptor-for-3racing-f103gt23-p-10000905.html If these parts are available now I'm not sure? I have the 3racing wheel adapter but cant use it for a F104. Anyone need them? Message me for price. Share this post Link to post Share on other sites
Jason1145 3986 Posted September 19, 2017 So this +2 makes the total hex width? ( what's a standard hex width?) Share this post Link to post Share on other sites
DaveBuildsRC 210 Posted September 19, 2017 Not sure if you can use a standard size with the f103gt rims. Specs for f103gt rims as follows 12mm hex, 52mm diameter, 24mm width , +2mm offset http://www.ebay.ca/itm/Tamiya-58376-F103GT-Courage-Subaru-BRZ-TA06-0440244-10440244-Black-Wheels-2Pc-/391776626878?hash=item5b37b4e8be:g:O9gAAOSwiwVWTxy2 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted January 1, 2018 Old thread, new year! It's been about 1-1/2 to almost 2 years since I last worked on this car. With the holiday break I'm making the most of it and trying to make progress on old projects. I built a new 3D printer recently to replace the one I gave away last year, and nothing was planned for today, so it was a great opportunity to model, print, and install a front grill on the GTR LM Nismo. Here's the model: And the 3D printed part done in black PLA: I painted the leading edges of the grill silver per reference photos and used some servo tape to mount it under the front bumper. Not too shabby, eh? Next up, the big aero ducts in the rear of the car... 5 Share this post Link to post Share on other sites
_oliK 108 Posted January 1, 2018 Cool! You just nailed the grille size! Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted May 15, 2018 All right! I think I'm going to declare this model completely done! It only took ~3 years to finish! Rear aero parts modeled... Front grill installed per before, but a nice natural daylight photo instead... Multiple details such as fender holes, front vents, and exhaust pipes per the real car... Note the rear aero ducts too! Closer look at the rear end... Finally, it's all done! 9 Share this post Link to post Share on other sites
Grastens 2795 Posted May 16, 2018 Excellent work - it looks stunning! I only wish Nismo put this much work into the car instead of abandoning it after one race 1 Share this post Link to post Share on other sites
TurnipJF 9192 Posted May 16, 2018 Superb attention to detail. Brilliant work! 1 Share this post Link to post Share on other sites
Blista 1519 Posted May 16, 2018 I might be able to ruin your day a little. I bought some wheels that would coincidentally be a much better match than the Tamiya supplied ones on your kit too. 1:1 Nismo wheels: And here's a photo I took of mine recently: Not much you can do about the lower profile tyres but the spoke design looks really similar. Here's the link: http://www.rc-mst.com/product_info.php?class_sn=22&class_sn2=130&sn=3066 1 Share this post Link to post Share on other sites
InsaneJim69 1584 Posted May 16, 2018 Looks great !!. And if you need a set of those Michelin tire decals Incan easily send you a set !! James. 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted May 16, 2018 @InsaneJim69 PM sent! @Blista Thanks for the tip; you're right, the MST wheels are more accurate to the Nissan spoke design. They're pretty reasonable, too, at $12 (w/ shipping) for a set of 4. Unfortunately I glued the tires to the original wheels, but maybe I'll pick up a set for shelf display and keep the original set for driving. Edit: Just ordered a set off the auction site. Share this post Link to post Share on other sites
Krstec 0 Posted July 26, 2018 @speedy_w_beans Beautiful build! Convinced me on this model over a f1 2012 f104! I really like your 3d printed parts, is it possible that you upload the cad models for the front/rear 3d parts here on the forum? now waiting for my own car on the post.... Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted July 26, 2018 @Krstec There isn't an upload area on this forum for files, but if you PM your email address I'll happily send them to you. Share this post Link to post Share on other sites
Krstec 0 Posted July 27, 2018 3 hours ago, speedy_w_beans said: @Krstec There isn't an upload area on this forum for files, but if you PM your email address I'll happily send them to you. Many Thanks for the files! Got them, great with the stl files, checking them out for ordering on 3dhubs.com. I intend it to be more of a basher/parking lot model but I typically end up always with building and never driving so can be no harm of getting some god looks to the model :-) Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted July 27, 2018 No problem; glad I could help. The front grill mounts with two pieces of servo tape between the front splitter and the grill's bottom tab: The rear pieces are held together with four fasteners and then the assembly is held in place with servo tape. For both the front and rear I'm using Parma tape, which I'm guessing is like a 3M VHB tape since it is way stronger than Tamiya's usual tape. The red strips mount the sides; there's also tape to secure the tail lights. So get yourself some thin, but very strong tape and it should all stay in place pretty well. 2 Share this post Link to post Share on other sites
Krstec 0 Posted July 27, 2018 Thanks! Yeah i love the VHB 3m tape, usefull for all :-) I have some kevlar cloth that i try to put in exposed places and skid places. However my local suplier after one week informed my that the supplier is out of stock (not suppried as the model is discontinued but more interesting as they claimed they haves two in local stock, sights:-( ) But some 2hour googling found me one in stock in Poland... I was extremely tempted to make it bruahless but read everywhere that for a novice driver it is overkill, so will be to get a mktronics brusched esc... I am also some into autonomous driving of rc cars, and for precision throttle controll brushed is still the “king” Share this post Link to post Share on other sites
