Sign in to follow this
Shaggy39
Trf503
Just bought one from tamico, can't justify but when can you! May race it at local indoor club but wanted to ask if 8.5 would fast enough? I have a motor/esc combo from a 2wd yoke that I'd like to use
8.5 will be fine, then if you go hardcore get a 5.5
If you are buying now get a 6.5 or 5.5 and turn down the speedo until you can handle more speed. Then once you can, turn it up and start adding boost and timing etc.
Carl
X2 what Carl said. Personally, I can't tell the difference between 5.5 and 6.5t motors. Since most here use 6.5 for 4WD mod, that is what I run as well, you will never run out of motor! I would much rather remove power via ESC settings than drive around a track disappointed that you don't have the speed or power you need/want.
