Hi Tamiya-freinds
I have started my first Tamiya build, a Scania R620 and have reached the point where the first stickers are going to be Applied. My earlier build have included decals, which seams a bit easier, as they can be moved around to the correct position.
Not so with stickers, one of the first ones (luckily a small one) went wrong at had to be moved resulting in peeling of the paint. Not so good!
Any advice in applying stickers would be nice. I'm a bit scared about the big sticker for the cab-sides.
By the way, below is a link to Flickr with some Pictures of my build so far. I think it´s quite nice so far.
More Pictures are on there way.
Regards Johnny
https://www.flickr.com/photos/134686869@N07/20601702776/in/datetaken/
That looks great so far !
There are ways to get them on and move them, some use a soapy solution to put on the decal and then wipe it dry, I also think windex or window cleaner works BUT I'm not certain.
Hopefully someone will post a solution, the Scania is a nice piece to assemble.
Thanks for the answer. Tried the soapy Water with a few small stickers and it went well. Now i'm les worried about the big stickers.
Regards
Johnny
I always use window cleaner (Windolene or such - not the cream obviously) for positioning stickers, get the surface nice and wet and you can move them around to get them where they need to be - then work out the liquid from the middle with a soft cloth.
