studioRS 213 Posted November 5, 2015 Well, been a while since I last posted... I'm taking the plunge, decided on building up a Porsche 959 based on the new MF-01X chassis set at 210mm. Ordered the following - 1/12 TGB P type 959 body - TGB P Type 959 wing - TGB P Type 959 interior - ******* 959 sticker set Need to buy - Jimny MF-01X - Options… :-) - RC Rally Raiders 959 1/10 wheels Looking for some insight on locating some 959 drivers heads. Anybody have any used bits they can part with? Don't fancy sporting for eBay units and can also craft my own. Interesting possibilities are Knight Customs SRB 3D printed head, helmet and visor. Just 1/10 scale and wondering if they could be scaled down? I do have several kits of the Toyota 4WD driver and could use the head only version, create a helmet and make a visor. Any other suggestions? TIA. Cheers, Thompson 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 5, 2015 Can someone be as kind to take measurements on a Porsche 959 drivers helmet? As much dimensioning as you can muster would be great, thanks. Share this post Link to post Share on other sites
waterbok 1282 Posted November 5, 2015 You don't need the Jimmy kit, you can get all the parts needed seperatly. Banzai has the chassis parts. The rest, arms etc are Mchassis bits if you're going for hopups that's the cheaper way. There's a PDF with parts you can get for the MF01. 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 5, 2015 @waterbok — thank you for this suggestion! I've downloaded the MF01 manual and options PDF. I'll start to organize the parts list and post it up here for ref. I used to own a 58059 kit in 1987 (see showroom), but now have the itch for another. I've never owned an M Chassis, so will try to gather that list of parts from a PDF as well. Good tip on Banzai, thanks. After I post the list, please chime in on any corrections. Share this post Link to post Share on other sites
ChrisRx718 4464 Posted November 5, 2015 It would depend on how well equipped you are whether it would work out cheaper buying in bits or a kit. I bought my second in individual bits because I have lots and lots of screws and spare parts (bevel gears, TL01 parts etc). If you don't have all this to hand it would probably be beneficial to get a kit instead. 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 I do have some TL01, bevel gear spares and yes 30+ years of extra Tamiya screws do add up, but I don't think enough to build this out in parts. Cheers, Thompson Share this post Link to post Share on other sites
Wez-li 1790 Posted November 6, 2015 Is there a definitive parts list for this project somewhere? Sounds interesting. 1 Share this post Link to post Share on other sites
njmlondon 570 Posted November 6, 2015 Well, been a while since I last posted... I'm taking the plunge, decided on building up a Porsche 959 based on the new MF-01X chassis set at 210mm. Ordered the following - 1/12 TGB P type 959 body - TGB P Type 959 wing - TGB P Type 959 interior - ******* 959 sticker set Need to buy - Jimny MF-01X - Options… :-) - RC Rally Raiders 959 1/10 wheels Now this is a project I have been waiting to see. Have too much on right now to tackle it myself, but from the second that the MF01X was released I wondered if they would re-re the 959 on it. Lots and lots of photos please! 1 Share this post Link to post Share on other sites
ChrisRx718 4464 Posted November 6, 2015 Essentially you'll need: 51576 A Parts 51577 B Parts 51391 C Parts 51425 F Parts 50738 G Parts That's the easy / cheap parts. The more complex requirements include: Propshaft (S/M/L) Bearings 20x 1150, 2x 850 & 2x 850 flanged Bevel gears 51008 x2 Drive shafts, cups, axles - I found it cheaper with aftermarket universals from 3Racing. Cups are expensive and harder to come by. King Pins (M05 option parts work) Suspension hinge pins, TL01 - 53301 Some 32mm & 18mm turnbuckles or threaded shaft Suitable ball connectors Gear shafts - this can be interesting, you need 2x 40mm, 1x 30mm and 1x 21mm. I ended up making my own On top of all that you'll need - 50mm dampers Wheels and tyres Lots of screws and ball connectors 06 Module pinion And electronics Silly things might slow you down though, like the large washers inside the differentials, or the gear shafts not being available at the time. Or the tiny screws which hold the diffs together, things like that. It's a good idea to print out the back pages of the manual and use a highlighter or pen to mark everything off if you have it! 1 Share this post Link to post Share on other sites
Wez-li 1790 Posted November 6, 2015 Essentially you'll need: 51576 A Parts 51577 B Parts 51391 C Parts 51425 F Parts 50738 G Parts That's the easy / cheap parts. The more complex requirements include: Propshaft (S/M/L) Bearings 20x 1150, 2x 850 & 2x 850 flanged Bevel gears 51008 x2 Drive shafts, cups, axles - I found it cheaper with aftermarket universals from 3Racing. Cups are expensive and harder to come by. King Pins (M05 option parts work) Suspension hinge pins, TL01 - 53301 Some 32mm & 18mm turnbuckles or threaded shaft Suitable ball connectors Gear shafts - this can be interesting, you need 2x 40mm, 1x 30mm and 1x 21mm. I ended up making my own On top of all that you'll need - 50mm dampers Wheels and tyres Lots of screws and ball connectors 06 Module pinion And electronics Silly things might slow you down though, like the large washers inside the differentials, or the gear shafts not being available at the time. Or the tiny screws which hold the diffs together, things like that. It's a good idea to print out the back pages of the manual and use a highlighter or pen to mark everything off if you have it! Would it not be easier to just buy the Suzuki kit then? or will it not be the correct dimensions/scale? 1 Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 Oh I forgot you also will need 9mm long 5mm ballscrews for attaching dampers. I used the standard tamiya bevel gears those with the ribbed shaft. I can try to make a list of what went into this little one. Only thing standard here are the gearbox/chassis bits 51576&51577 and driveshaft rest is all non-kit. Its not that hard to make your own driveshaft or modify one. The chassis is waiting for universals to arrive and an solution for the front upper arms (those are very narrow) For gearshafts I got the WR02 hollows those are cheap and 50mm (or use whats left over from the driveshaft ) Oops, one thing none tamiya the front mount thats 3racing 3R-M05-23/LB 1 Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 Noticed that 1 or 2 bits might be needed but not necessarily - front bumper - battery side thingies (3racing has some alloy bits for that) - rear chassis mounts, most other tamiya will fit 2 Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 Sorry that we are not much help for the driver search. 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 @waterbok — Great photos and completed chassis from misc. parts. This really opens my eye, certainly gets one thinking "outside of the box" for future projects. Can't thank you enough for this spark. Awesome, this thread has totally taken off, yes I plan to upload lots of photos of the build. You guys are welcome to add your builds in too. In an effort to add to my future builds, parts stable and one shipment in the post, I'm going to purchase a full MF-01X Jimny kit. I'm sure someone here will need a spare Jimny body, decals set and rims. Just to keep enthusiasm for this thread on track… my ex-58059 Porsche 959 roosting at the beach, 1987. ps… anyone have any Porsche 959 driver head (+mirrors, top brake lights) they are willing to lend for a proper resin moulding? I'm also working on 3D printing of these too. Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 @waterbok — no problem on the driver heads, we can make new versions Share this post Link to post Share on other sites
Droopy1975 39 Posted November 6, 2015 I have those parts, you can pm me. 1 Share this post Link to post Share on other sites
njmlondon 570 Posted November 6, 2015 Just to keep enthusiasm for this thread on track… my ex-58059 Porsche 959 roosting at the beach, 1987. What a great photo! And where did you get those amazing wheels? 1 Share this post Link to post Share on other sites
ChrisRx718 4464 Posted November 6, 2015 Waterbok - I made my own miniature front upper arms using a set screw and some cut-down ball adjusters. However, I'm now looking to replace them with some standard items, as the front suspension geometry is strange when compressed. I think the rigid front arms help to hold the suspension 'square' if that makes sense, whilst compressed. I'm thinking of getting Tamiya 54529, but the price seems high for what you actually receive! 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 On 11/6/2015 at 11:39 AM, njmlondon said: What a great photo! And where did you get those amazing wheels? Thanks! Photo was shot by myself driving one-handed on my belly in the sand and holding my Minolta XG9 35mm manual focus… Back in the day, I made the covers out of hand painted, hand cut lexan and glued these over the inaccurate yellow Tamiya rims. Today I would do the same on lexan, but illustrate a vector version from the real version rim. I will do this illustration and offer for free to us all. Here are the other shots from that day. I wish I had taken more photos back then... Joel Johnson even drove this exact Tamiya 959! Cheers, Thompson  1 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 @Droopy1975 — thank you for the offer Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 Thanks! Photo was shot by myself driving one-handed on my belly in the sand and holding my Minolta XG9 35mm manual focus… Nice action shots, lol, still use an XD7 with B&W film every now and then on holidays, got an XM and XD5 too 1 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 Like my ex-Porsche 959 I sold off my Minolta XG9… grrr. My camera today is an Olympus E-500 DSLR 4/3 with Olympus Zuiko 50mm ƒ1.4 and Zuiko 135mm ƒ2.8 lens. Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 One remark, dont make list when the misses is hanging around. :lol: This is about what you can sink into the MF01x or need without getting the kit, gives you a fully hopped chassis without wheels/body/motor/electronics Yen MF01x Chassis 1 975 975 51576 MF-01 X A Parts 1 825 825 51577 MF-01 X B Parts (Damper stay) 1 2250 2250 54643 MF-01X Ball Bearing 1 450 450 50738 TL01 G Parts (Gears) 2 225 450 50602 Diff. Bevel Gear 2 195 390 54586 5x50mm LW Gear Shaf 2 675 1350 53322 Hollow Carbon Gear shafts 2x40 1x30 1x25 1 210 210 54655 L Wheelbase Propell or 1 210 54654 S Wheelbase Propell 2 450 900 53218 Gear diff. Hard Joint Cups 1 1125 1125 54660 MF-01X Alum Motor Mount 1 1200 1200 54658 MF-01X Alum Servo Mount 1 1125 1125 54120 HT Servo Saver Alum 1 525 525 51000 Hi-Torque Servo saver 1 300 300 54249 Aluminum Turnbuckle 3x32 steering 1 450 450 53346 TL01 / M03 Quick Release Battery Suspension 1 1050 1050 54659 MF-01X Carbon Damper stay - rear 1 825 825 54320 Carbon Damper Stay - front 0 825 0 50746 CVA Super Mini Shocks or 4200 54000 M Chassis Alum Damperset or 4875 42273 TRF Short Damper 4p 1 375 375 51425 M05Ra F Parts - Uprights (black) 1 525 525 54606 One Piece Lwr Sus Arm set or 2 495 54614 M-05 Carb Reinf L Parts (Sus Arms) 1 450 450 54237 M05 Low Friction King Pin 1 300 300 53301 TL01 Stainless Suspension Shafts 1 300 300 53585 3mm Shim Set - 3 Types 2 1500 3000 53597 M03 Assembly Univ Shaft 1 1125 1125 53823 RC Clamp Type Alu wheel hub 1 300 300 54247 Alu Turnbuckle Shaft 3x18 rear upperarm 1 1050 1050 54529 M05 Front Upper Setting Sus Arms 1 675 675 51391 M05 C Parts - Susp/Bodymount/bumper 1 300 300 50855 - TL01 E Parts Bodymounts #9805611 | RC 5x9mm Ball Connector 1 525 525 53969 Hex Head Ball Connector - 5x8mm 1 225 225 53601 - 5mm Adjuster - Low Friction 3x10/12mm Self-Tapping screw O-rings copying an excel sheet didnt quite work out well ok was a little shocked meselve too when it totaled around 24000 yen 2 Share this post Link to post Share on other sites
studioRS 213 Posted November 6, 2015 Whoa—very cool, thank you for the complete list! Super ref. with links for MF-01 X optional parts too. Share this post Link to post Share on other sites
waterbok 1282 Posted November 6, 2015 Instead of universals you could get dogbones and the hardened CR01 driveshafts, but thats almost same price as I haven't found a cheap address for those. 1 Share this post Link to post Share on other sites
