Forgive me tamiya club members as I have sinned, :wacko:
ordered one of those new fangled X-maxx trucks :ph34r:
should take delivery in feb :)
This probably should have gone in the "what have you done today post"
This probably should have gone in the "what have you done today post" <<<Made a mistake today :lol:
Now mister , For your BIG sinnnnnnnn , you must , Buy all tamiya members A MF-01X ! :lol: ..
don't worry , I was tempted to order one , ,$1450 aud kinda put me off though. I did get an email from traxxas yesterday saying that a handful of bl rigs are now ablr to use the self righting technology , need to have one of those new fan dangled receivers though
Have ordered a new receiver to fit to my E-Maxx, already have a blue tooth module
I think the self righting thing will kill the standard diffs.
Mine has 1/8 buggy diffs fitted.
Want to see if the stability bit makes it easier to drive at high speed.
Xmaxx wise i have got a couple of shocks, and a spare diff coming, found them on eBay from Jenny's Rcsports store
from online forums the only breakages seem to be shocks, and a diff.
Ok an update. received shocks, motor and a diff
my truck is on pre order and am being told february delivery
Have also ordered spares from tower hobbies, none in stock in UK yet.
breakables like wishbones, spur gear, steering hubs castor blocks and hinge pins.
The Tsm receiver i got for my e-maxx, was faulty.
It wouldn't bind, so have had to send it back, dealer has sent it to traxxas and i am awaiting a replacement
Wow those shocks are huge! I bet they could replace some on a 1:1 scooter!
I've never heard of or seen one of these before but just looking at the parts means it will be an absolute monster!!
Postman bought me a few bits
the slipper clutch, main prop shaft, gears and a motor heat sink
Main truck is still atleast 2 weeks away from delivery
Update,
Traxxas have with held all euro imports after a "quality control issue"
Esc's catching fire, wheels cracking, shocks leaking and breaking probably didn't help.
So have Cancelled my preorder, and instead I will build my own from parts.
ebay chop-shops should make things easier.
Omg. That doesn't sound too good which is a shame as it looks amazing! I've built an rc from sourcing parts from here and there and it's great fun finding everything and putting it all together.
update,
got a delivery of a chassis from an eBay chop shop.
also a large delivery of parts from tower hobbies
1st pic of 1st delivery
last pic is build so far, still awaiting drive shafts and a pair of shocks.
Will be using standard traxxas radio gear, the "special servo" is on its way (it doesn't use standard mounts, it has custom mounts for the x-maxx chassis)
Have a castle xlx esc on order, want to run on 6s with option of 8s at a later date.
Stock gearing, as want to see how it performs stock before changing things.
The preordered trucks still haven't been delivered to uk customers yet
Quote
"The preordered trucks still haven't been delivered to uk customers yet"
Well the trucks have finally hit the shores of Europe.
I have had some delivery of spare parts, just not the bits I need to complete the build :rolleyes:
spare arms, shock shaft, stainless screws
Been told the trucks in the uk are in the 4000 range of chassis numbers,
my chassis is in the 300's as it's imported, nice low chassis number B)
Have used all stainless screws.
Temporarily have taken the esc out of an E-maxx, just to try the standard motor on standard gearing.
Will be wiring in the gps expander to see what speed each gear ratio gives.
Ideally I want about 45mph on 6s
I got the kershaw mount for the castle 2028
I intend to paint the body up this weekend, going to need a lot of tins
That thing is huge! Looks like it will be lots of fun. I don't think running in long grass will be a problem :lol: . It makes the monster beetle look like its scale is about 1:20 .
Hope you do a running vid of it. B)
Yes it is big,
when I started building it, you don't realise how big its getting until you fit the wheels.
As to vids, there are a few on Utube already.
guy in the following vid knows how to jump :)
https://youtu.be/ewtoDlC8QlA
I won't be jumping mine
will run a full set of 5000mah lips tomorrow, need to check temps.
Have the big castle set up here, and will probably fit that next weekend, as I have a pair of 4s batts coming from hobby king
Ran the truck today,
2- 3s traxxas 5000mah till the cut off.
truck handle rough ground easily
couldn't get the gps unit to work so no speed readings to report
just seemed to need a bit more oomph on the straights
so
out came the standard 1600kv and in went the 2028 set up
running 32t pinion with 54 spur, so its a little faster than stock.
will order bigger pinions, as the motor has got enough torque to go larger
Took the X down to my local park today to try out the new motor combo.
On 6s it is about the same as stock,
But, on 8s the X does come alive.
The tyres just start to balloon at full speed, so I think the gearing is about right for the stock tyres.
Have had a new 49tooth pinion delivered.
Truck seems a fair bit quicker.
Still need to play with the esc parameters, punch, etc
Damage wise,
Crack in the rear of the body after a cartwheel,
Broke a front shock shaft after colliding with a fence post, it broke the shaft just as it screws in to the bottom swivel joint.
Must not have gotten the pinion grub screw tight enough as pinion has moved on the shaft, luckily I saw it before any damage.
The XLX esc has a data logging feature
I have fitted the castle 6mm battery connectors on the 4s batts (8s set up) and get very low ripple volts when running these connectors.
On my 6s set up (two 3s batts) I use traxxas connectors, I made up a small conversion lead to plug in to the castle connector.
With the traxxas connectors i am getting a ripple voltage of around 0.9 to 1 volt.
So it seems the "Traxxas high current connectors" are not up to the job of feeding the XLX esc
