Apart from the obvious different hubs & extremeties parts... are the axle cases and innards the same (ie Interchangeable) for both early & later trucks?
They look pretty identical.
The front is the same, but the rear is different:
hilux/blazer has axale collars for flanged ballbearing
bruiser/mounty has axale collars for normal 850 bearings
So the difference is only inside, but if you are a purist...
Roby
Good point Roby.
Was just studying the manual for Hilux & Blazer and I noticed the flanged bush, was wondering if I needed a flange bearing or if I could get away with a unflanged one.
Did Tamiya ever sell flanged bearings? [?]
The rear axle is different also. the Hilux uses an E clip to secure the rear hub while the Bruiser uses a 3mm bolt.
id="quote">id="quote">
I never noticted those differences before..? But now that I think of them, it makes sense... Jim, I think you mean a 3mm NUT though, not a bolt... [:)]
