stellamodels 18 Posted January 5, 2016 Something to interest you? 10005186 C-Part : 58577 Novafox 10005188 F Parts : 58577 Novafox 10115037 R Parts : 58577 Novafox 10115106 S-Parts (S1 x2, Red) : 56301 King Hauler 10225182 Y Parts (1 Pc.) for 56323 Scania R620 13404035 Servo Mount Bridge for 42275 TRF503 84379 TB Evo 6 13404036 Rear Damper Stay for 42277 TRF201XMW 13454926 TRF418 Servo Mount 13454971 Servo Mount (Blue) : 42275 TRF503 13454978 Gear case (left) : 42277 42288 13454979 Gear case (right) : 42277 42288 13505023 15T Pinion Gear : 58441 13515001 13T Pinion Gear : 58391 Hotshot 13515003 15T Pinion Gear : 58391 Hotshot 13515004 16T Pinion Gear : 58384 13515006 18T Pinion Gear : 58384 14045016 Roof Wing Plate : 84389 Fighting Buggy 16244030 Drive Belt (Long and Short) for 42275 TRF503 19004176 A-Parts for 42275 TRF503 19005073 F & R Parts (2Pcs. each) : 58441 19005162 F & R Parts (2Pcs. each) : 58496 19005282 D Parts : 58489, 84270 19115192 R Parts : 58391 Hotshot, 58517 Super Hotshot 19115212 L Parts (L1-L9) for 56319 19115273 K Parts for 56325 19115280 R Parts for 56325 19115281 S Parts for 56325 19335685 Body for 56335 19335696 Wheel (Front x2, Rear x2) for 58577 19405862 Shaft Bag : 56302, 56306, 56310 19415073 Gear Bag for 56505 19495452 Sticker Bag : 58336 The Hornet 19804230 2mm Nut (10Pcs.) : 58441 19805034 Rear Tires (1pr.) : 58336, 58354, 58527, 84389, 47304 19805337 Wheel Hub for 1/14 Tractor Truck & Semi-Trailers (2Pcs.) 19805458 Diff Shaft A & B : 1/14 R/C Tractor Trucks 19805556 2x8mm Screw (10Pcs.) : 58441 19805757 3x55mm Screw Pin (4Pcs.) for 58593 M-05 Ver.II 19805868 2x10mm Screw (10Pcs.) : 58441 19805997 18T Pinion Gear : 58346 19808178 Drive Shaft A & B : 58405 1 Share this post Link to post Share on other sites
Butler 338 Posted January 8, 2016 Hi, are you due 84366 WR-02 CVA Mini Shock Unit Set II Yellow Style soon? Thanks Marc 1 Share this post Link to post Share on other sites
matman 1498 Posted January 8, 2016 Hi, are you due 84366 WR-02 CVA Mini Shock Unit Set II Yellow Style soon? Thanks Marc I hope so , BUT it's a 84 number LTD release . Share this post Link to post Share on other sites
stellamodels 18 Posted January 14, 2016 Hi, are you due 84366 WR-02 CVA Mini Shock Unit Set II Yellow Style soon? Thanks Marc Hi Marc, all our suppliers are currently out of stock on this limited edition item with no info on the next batch restock. Regards, stellamodels 1 Share this post Link to post Share on other sites
