s howell 28 Posted January 12, 2016 I got this in a job lot of rc gear and have 3 receivers, i see that the hand set can run up to 4 vehicles but my problem is that i am setting it up on one vehicle and i cant get reverse. I am working from a pdf copy of the instructions but cant see anything on switching the reverse function on and off, i had both when running it on my acoms 2.4 set up. Share this post Link to post Share on other sites
XV Pilot 1936 Posted January 13, 2016 Assuming it isn't an ESC calibration issue, the most likely cause would probably be your EPA setting on the throttle channel for that model memory. Is it set to zero in reverse by any chance? Share this post Link to post Share on other sites
s howell 28 Posted January 13, 2016 I will have a look when im in my cave tomorrow evening, i guess if you can adjust bits like that it will be ideal for my crawler as well Share this post Link to post Share on other sites
XV Pilot 1936 Posted January 13, 2016 You can adjust all sorts of useful stuff - I am sure it will suit your crawler very nicely. Share this post Link to post Share on other sites
