You'll need to open the diff in order to insert the bearing (open the hex screw that's inside the outdrive that does not come apart). if the instruction sheet was included with the kit it says it very clearly, and it includes a nice exploded diagram of the diff parts. When you open up the diff you should really clean up and regrease it as it was probably laying around somewhere for years. use ball diff grease such as associated stealth diff grease etc.
