Hello everyone.
I have read and looked up different chassis and ended up getting confused.
I have just bought a standard TT02 chassis and find its a bit to long for my project.
What options do I have it needs to be either 4x4 or rear drive.
Many thanks everyone.
If you only need it slightly shorter, you can reverse the rear suspension arms (assuming it is a normal TT-02 and not a Type S).
What he said, TT02s can be 257 or 251 mm wheelbase. I've ran my TT02 in both configurations. They will both be 185mm wide.
If you want something shorter, but 185mm is okay a TA02 with reversed arms will give you 230mm (or with TA01 rear arms will give you 237-239mm).
If it's narrower, you need an M-Chassis of some sort. 4WD m-chassis include: Hobby King M.Rage (210mm wb, or 220 if you flip rear arms), MF01x (210,225,239 configs) are currently produced and 4wd. OOP 4wd m-chassis include HPI Cup Racer, Active Hobby 210SS (rebranded as Ofna JL12e), or Nanda NRX-12 (which became the M.Rage).
And if you want an overly heavy Touring Car.. you can buy a TA03 and buy an appropriate tub and belt to shorten it (comes as mid-rear-engine or front engine). I sold mine once I found out you can convert a TA05 to 239mm wheelbase with proper arms and spacers.
