Ian_Gsi16V 533 Posted March 14, 2016 Hi, Noticed this weekend that my Blitzer is running very hot Spec is: Fully Ballraced 2S LiPo M-Troniks Storm No Limit ESC Yokomo Pro Stock 14 Turn (about 20 years old) 13T steel pinion Proline Dirt Hawgs Running on a mixture of tarmac / gravel / sand. Have ran the Blitzer a few times this weekend and the motor is getting very hot, burnt myself twice on it and yesterday one of the motor wires de soldered itself it got so hot Any idea what this could be? Was under the impression that the blitzer is pretty good at hot motors, the super stock BZ I had in it barely broke a sweat but that was only 23T. Could it be a faulty motor? As mentioned above it is very old, be a shame to remove it as it is very quick with it and I don't want to go brushless just yet Share this post Link to post Share on other sites
Darat76 265 Posted March 14, 2016 check to see if the motor spins fairly easy, or if it takes some effort, otherwise your gearing is to tall for that motor 1 Share this post Link to post Share on other sites
chickenman242tk 266 Posted March 14, 2016 what sort of condition is the motor in, I too run a bz in my bearhawk and its a great motor , I do have a 14t double sitting on a shelf ready to but the bz is more than quick enough. I'd pull the motor down and check the brushed and comms for sure , maybe true it up and a new set of brushes may help and also check the timing on the motor , it may have advanced itself or something. Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted March 14, 2016 The motor has never had any maintenance, I got it as a 13 year old in around 1995/6 and have pretty much just used it and abused it since (it did spend at least 10 years sat in the loft though). I'll have a look at it this week, I can put the BZ back in as it was good enough with that in but I am one of them guys that if I see a way to go quicker I am taking it Share this post Link to post Share on other sites
chevelle 997 Posted March 14, 2016 It seems your Blitzer Beetle is cursed and will never run well again You should box it up and ship it to me Or you could put a larger turn motor on the poor thing, I doubt your trying to do much more than have some fun Remember: less turns = higher rpm but less torque, stop start stop start stop start = high load = Heat Share this post Link to post Share on other sites
chevelle 997 Posted March 14, 2016 Ooh & if you really want it to go faster and run cooler go brushless Share this post Link to post Share on other sites
Darat76 265 Posted March 14, 2016 I'd be surprised if increasing the pinion tooth count would help, as that will increase your final gear ratio, which increases the resistance being loaded back from the wheels to the motor, if anything, I'd decrease the pinion with the hot motor, or install the bz and increase the pinion. first thing tho, clean out the hot motor, then try again, if solder is melting the whole motor is getting to internal damage causing temps Share this post Link to post Share on other sites
chickenman242tk 266 Posted March 14, 2016 a 13t pinion is the smallest you can go but I doubt that would be the issue , is suspect a dirty motor or badly worn brushes. can you post some pics of the motor internals? Share this post Link to post Share on other sites
chevelle 997 Posted March 14, 2016 I'd be surprised if increasing the pinion tooth count would help, as that will increase your final gear ratio, which increases the resistance being loaded back from the wheels to the motor, if anything, I'd decrease the pinion with the hot motor, or install the bz and increase the pinion. first thing tho, clean out the hot motor, then try again, if solder is melting the whole motor is getting to internal damage causing temps Your right, I rushed through that I edited my post to be about turns not pinions Share this post Link to post Share on other sites
lentner3 281 Posted March 14, 2016 I'd say 14t motor is pushing a bit especially if it is in poor condition. get the smallest pinion that it accommodates, maybe get a heat sink and make sure there is plenty of air flow around the motor. and clean up the motor , 23 down to a 14 turn motor is a big increase. Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted March 14, 2016 I'll get the motor stripped down the check it out. Brushless is undoubtably the key especially as most of my running is done on the beach so a motor that doesn't have brushes etc to trap sand would be much less maintenance. It does end up looking like this after most runs... 2 Share this post Link to post Share on other sites
lentner3 281 Posted March 14, 2016 that is some cool terrain Share this post Link to post Share on other sites
Darat76 265 Posted March 14, 2016 I think that blitzer needs a new name... something like... sand blasted beetle.... 1 Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted March 14, 2016 It is so good on the sand, I was doing power runs into big long 10 ft drifts, just need the sand to be a little less wet. Hands down one of the most fun cars I have driven. Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted March 14, 2016 Thread started regarding how to dissasemble the motor in the relevent forum..http://www.tamiyaclub.com/forum/index.php?showtopic=79213 Share this post Link to post Share on other sites
tonysmini 19 Posted March 22, 2016 Over geared, it may have been okay with the stock tyres but Dirt Hawgs are bigger still. Your motor is really struggling. Try an EZRun Brushless. I ran a 10t set up in mine and it was stupidly fast. Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted March 22, 2016 I plan on going brushless at the end of the month Share this post Link to post Share on other sites
