Seeing I got the bruiser finished this week I thought I would fire her up.
And the steering is hopeless it turns nearly all the way to the right but the left don't want to know.
If I take the weight of the front it turns both ways nearly a complete cycle.
I have sailed the hightorquesrvo saver for the kit one to see if it was that.
The only thing I have noticed is the servo don't turn very far when the saver is off.
I also noticed the steering rod catch's on the chassis rail but not is not tight on it.
I am running the spectrum dx6 ... Know is their settings on this to make the servo travel further.
Can't really comment on the other issue, but the steering rod touches the frame, both on my 1988 and my ReRe -shouldn't be an issue though.
What servo are you using, is it man enough? Have you used all the metal rings that come with the kit saver? Do you have a pic of the front setup. Ie is bracket on the steering hub the right way around etc and the steering rod correct orientation and the like?
