You mean like a Hotshot/Boomerang style front end set up? I think the fact it only has the 1 arm each side is the main problem.
I do run it at full travel, so I'm guessing a sway bar might hinder that a bit maybe. I was thinking of how the back end rocks back and forth (without compressing the damper) much like a stock Fox front end (which the optional sway bar helps in this case). I do like how the Super Champ's monoshock works. It's too much a part of the car's character to eliminate altogether. I just wondered if a sway bar would help some.
