bsy2010 218 Posted April 19, 2016 Hi there, I've checked everywhere else, and didn't get much info, so I try here... From my old racing days (long, long time ago), I still have this CS Rocket 6, without cables and no idea where to put motor and battery. Maybe someone here has the same ESC and share a picture, or, someone might have the old data sheet for me. I already asked CS in Germany, but they didn't keep any records Thanks for your help Share this post Link to post Share on other sites
Percymon 2184 Posted April 19, 2016 any help ??? https://classicrc.wordpress.com/esc-electronic-speed-control/cs-electronic/cs-rocket-6r/ 1 Share this post Link to post Share on other sites
bsy2010 218 Posted April 19, 2016 Thanks @Percymon, seen this before as well. But can't figure out where the battery minus is going Share this post Link to post Share on other sites
Backlash 481 Posted April 19, 2016 bsy2010, Can you see a hole in the PCB, if you look down between the orange capacitor, and the MOSFETs on your ESC?? I suspect that the hole will be covered by solder on the track side of the PCB, but it should still be visible on the component side.. Your ESC looks to be forward only, and the one that Percymon posted appears to be Forward / Reverse.. If your ESC is forward only, then the battery positive and the motor positive most likely solder to the same point on the ESC.. 1 Share this post Link to post Share on other sites
Backlash 481 Posted April 19, 2016 Its a little hard to tell without having the ESC sitting in front of me, but I suspect that the battery negative wire solders through this track that I've circled in red.. 1 Share this post Link to post Share on other sites
bsy2010 218 Posted April 20, 2016 Its a little hard to tell without having the ESC sitting in front of me, but I suspect that the battery negative wire solders through this track that I've circled in red.. You might be right, this part look as if I have soldered there before Share this post Link to post Share on other sites
