Pintopower 1456 Posted April 28, 2016 Hey folks, I have been doing some work on my CW01's lately, trying to ignore my hatred of Project Hor-Cha-Hop. I made some Midnight Pumpkin body mounts and a brace for the transmission to stop the irritating slap of the trans under torquing. My current design has to do with my double wishbone front end upgrade on the Hornet. I am working on an updated version akin to a Grasshopper II where the shock is sunk deep into the arm. This will allow you to use a 50mm touring car shock. However, this "sunken" shock mount setup will not work on a CW01, nor will it work if you want to keep the friction shocks on a Hornet/Hopper. So I made one that leverages the Tamiya steel spring mount. Tested on the Hornet and it is perfect. I installed in on the CW01 and there was an unexpected change; wheel track. The front of the CW01 is now 15-20mm wider than stock. Now this is very desirable if you want to run and jump the CW01's hard, it makes them much more stable. If I shorten the arm by 10mm, it will do a few bad things. 1. The upright will come closer to the shock mount and hit the shock. This will require moving the shock more inboard. 2. The shock needs to move inboard. Ignoring the above issue, narrowing the track will result in forcing the shock to move proportionally to the shortening. this now reduces the lever arm on the suspension arm reducing travel of the shock (not the wheel) and also inadvertantly raising the front end. I think I am correct in beleiving that widening the front end is a better route since anyone that would install this (like me on my race truck) wants more stability. Plus, the drawbacks to narrowing the front end are seriously bad. Love to hear some input. Here is where the testing is (had to borrow SuperFly's upright): The widened track from the front From above (sorry, black floor) Also, the upper link will mount to a part that will be wedged by the servo with no screws. This means that this mod will require zero holes or alterations to your CW01. I hate drilling and cutting on stuff I paid for. The MP Mounts are working great on a side note. I change the direction of the pin holes on t he front mounts and made a nice base for the rear body to sit on. Fits perfect on stock body with no mods needed. The trans brace has made the trucks so much less annoying too. Simple little part and easy to install. 2 holes, sorry. There are also Wheelie bar wheels and Lunchbox body mounts that come in all the shapeways colors. I think that's all for now. All that stuff is in the store under CW01 or MP/LB depending on how specific it is. https://www.shapeways.com/shops/ampro 5 Share this post Link to post Share on other sites
Pintopower 1456 Posted April 28, 2016 Ok I made 2. That wasn't so hard. The lower one should have nearly zero offset. The top will be +20mm total. Now I need to test them. 3 Share this post Link to post Share on other sites
Pintopower 1456 Posted May 2, 2016 So here is the center support: It allows for the pivot points for the arms and upper length to be equal. Also note, there are zero holes drilled anywhere on the chassis for this upgrade. I am happy about that. The offset with the new arms: Now I need to order some from shapeways since my material is way to hard and brittle. Keep you posted. 5 Share this post Link to post Share on other sites
skip665 169 Posted May 3, 2016 Loving this development Alberto! I think the Frog hex adaptors will give the truck a slightly wider rear track so will be a closer match for the wider front track you have created. http://www.rcmart.com/tamiya-53913-frog-2005-wheel-adapter-p-18599.html?cPath=595_744_972 I have both setups at home so will try and have a measure up at some point. Share this post Link to post Share on other sites
Nobbi1977 1793 Posted May 3, 2016 Not that I have an LB but how about arms that will take front C hubs to give people the chance to run hexes all the way around? Would open up this model to a huge of wheels and tyres Share this post Link to post Share on other sites
Pintopower 1456 Posted May 4, 2016 23 hours ago, skip665 said: Loving this development Alberto! I think the Frog hex adaptors will give the truck a slightly wider rear track so will be a closer match for the wider front track you have created. http://www.rcmart.com/tamiya-53913-frog-2005-wheel-adapter-p-18599.html?cPath=595_744_972 I have both setups at home so will try and have a measure up at some point. Oh man you are right. I have some too that I can test out with some King Blackfoot rims. I didn't think about that. 23 hours ago, Nobbi1977 said: Not that I have an LB but how about arms that will take front C hubs to give people the chance to run hexes all the way around? Would open up this model to a huge of wheels and tyres Hmmm, that is a thought but the issue is the shock mount. I cannot move it in any more any mounting it elsewhere would require some weird geometry and way more material, skyrocketing the price of the parts. As it is, the shock mount cannot accept anything more than a shock of 18mm Diameter. There is about 0.5 gap between it and the upright with the short arms as it is. That is already uncomfortable for me. I like the idea and will see what development brings. 1 Share this post Link to post Share on other sites
skip665 169 Posted May 5, 2016 11 hours ago, Pintopower said: Oh man you are right. I have some too that I can test out with some King Blackfoot rims. I didn't think about that. I have a CW01 with a set of Wild Willy rims which mimic the look of the standard wheels. I dont think the back spacing is any different to the standard wheels. Share this post Link to post Share on other sites
Pintopower 1456 Posted May 5, 2016 9 hours ago, skip665 said: I have a CW01 with a set of Wild Willy rims which mimic the look of the standard wheels. I dont think the back spacing is any different to the standard wheels. So the offset is the same as the stock wheels + the hex adapter which is like 15mm thick right? Share this post Link to post Share on other sites
skip665 169 Posted May 6, 2016 15 hours ago, Pintopower said: So the offset is the same as the stock wheels + the hex adapter which is like 15mm thick right? Yup - just about.. Its only a subtle difference but it is slightly wider... Probably 5mm or more.. Share this post Link to post Share on other sites
Pintopower 1456 Posted May 6, 2016 7 hours ago, skip665 said: Yup - just about.. Its only a subtle difference but it is slightly wider... Probably 5mm or more.. Oh I like that idea. Share this post Link to post Share on other sites
Pintopower 1456 Posted May 10, 2016 Guess who is getting a light kit? An not its not stopping at the tail lights. When I do lights, I do lights. 1 Share this post Link to post Share on other sites
Darat76 265 Posted May 10, 2016 oooo sweet, I'll be able to do this with my black edition when I finally pick it up Share this post Link to post Share on other sites
StrokerBoy 772 Posted May 11, 2016 18 hours ago, Pintopower said: Guess who is getting a light kit? An not its not stopping at the tail lights. When I do lights, I do lights. Not sure I can squeeze any more in. Share this post Link to post Share on other sites
Shodog 1835 Posted May 11, 2016 Awesome, I admire your skill in creating these parts Share this post Link to post Share on other sites
Pintopower 1456 Posted May 11, 2016 Thanks guys. Here is a mint body completely ruined now: 2 Share this post Link to post Share on other sites
Darat76 265 Posted May 11, 2016 10 hours ago, StrokerBoy said: Not sure I can squeeze any more in. I can see loads of space for more lights in there Share this post Link to post Share on other sites
StrokerBoy 772 Posted May 12, 2016 8 hours ago, Darat76 said: I can see loads of space for more lights in there Yeah, I should probably have done the orange marker lights on both sides too. It's not too late... 2 Share this post Link to post Share on other sites
Darat76 265 Posted May 12, 2016 and spot lights, driving lights, and my personal favorite, the "blind that idiot" light Share this post Link to post Share on other sites
Pintopower 1456 Posted May 13, 2016 On 5/12/2016 at 1:09 AM, StrokerBoy said: Yeah, I should probably have done the orange marker lights on both sides too. It's not too late... Yeah, it needs more lights. Share this post Link to post Share on other sites
Darat76 265 Posted May 14, 2016 I just noticed it's missing the 50 cal roof mount, and the side mounted dual gatling's..... And just realized, the lunchbox has more than ample space to fit a light and sound kit, unlike some other kits out there.... Share this post Link to post Share on other sites
Pintopower 1456 Posted May 19, 2016 My lunchbox has real suspension! Here is the sprue for the zero offset front end that I used on the LB: Here is the 8mm offset version (8mm per side) The zero offset front end is tight for the shock so one of those massive big bore set ups won't fit. You can also adjust the position of the upright with 2 washers. This helps keep part cost down and allow for adjustment. I moved the upright all the way forward to make sure the upper link clears the spring. I forgot a pic of the new center mount installed so here is the old one. Zero additional holes or any cutting of any sort is needed. All assembled: I gave it 3 deg negative camber: And now under compression! I just ordered another set for my Midnight Pumpkin. Man I am happy with this one! If anyone is interested, they are here: Zero Offset for stock sized shocks and stock travel: http://shpws.me/McXB 8mm Offset for more shock options and increased travel http://shpws.me/McXv I hope you enjoy! 2 Share this post Link to post Share on other sites
jupitertwo 1484 Posted May 19, 2016 Nice one, very tempted with these! I'll start looking in to some turnbuckles Share this post Link to post Share on other sites
