Hi all. Anyone know if it's possible to bind a Tamiya FHSS receiver like the TRU-08 with a recent Futaba FHSS transmitter?
I've got a Futaba 4PRKA T3PRKA and wondered if this might work as it seemed some older Tamiya receivers were rebadged Futaba stuff.
Cheers, Jim
To report back, I just tested this and it seems it's a no.
Can't bind the TRU-08 to a 4PRKA, maybe as the transmitter doesn't have the bind button on it that the Tamiya transmitter does.
Cheers all!
  • 3 months later...
Cheers all!
I realise this is old but a] thanks for reporting back and b] The 4PK (never heard of a "4PRKA", got a link?) Tx's are auto-bind, you just need to turn the Tx on and press the button on the Rx whist making sure there are no other FHSS devices in proximity.
http://www.competitionx.com/pdf/radio-equipment/futaba-4pks-2_4ghz-manual.pdf
I've tested this with a Futaba 4YWD transmitter as well.
It will not bind.
It binds with the Tamiya FineSpec2.4 transmitter in less than a second.
Note that the 4YWD is a 4 channel transmitter and the TRU-08 is 2 channels. I'm not sure that it should bind.
The 4YWD transmitter is also sold by Tamiya as a rebadge in the high lift complete kit and it is perfectly cross-compatible with the Futaba version.
Oh hey, sorry I made a misleading typo in the original post. It's a Futaba T3PRKA, not 4.
Thanks for confirming I wasn't just missing something obvious here trying to bind with the Futaba.
Luckily I picked up the receiver with a matching Tamiya transmitter for just a couple of quid extra which binds and works just fine.
Thanks again!
