From memory the stock pinion is a 19 tooth at 0.8mod. The txt-1 I think is a 16 tooth because of the bigger wheels/tyres. You can run a 32 pitch if you want, but if you have access to a 0.8 module then get one of those as it will correctly match the teeth on the spur.
