Truck Norris 2237 Posted August 30, 2016 I'm keen to find out how it sits too, not that it will affect me getting one - I've already planned to use the chassis for my 993 GT2s. Tamiya seem to be very careful with the wheelbases on touring cars - shorter chassis for the Corolla, Capri, 49400 934 etc but way off for some pickup trucks (Blackfoot Xtreme, Bush Devil II). I've checked the manual for this and I can't spot any differences to the GT2 so unless the body has been altered, which seems unlikely, then I think it will be out. The part number for the body is different to the 49400 but I think this is probably due to additional dimples in the mould to show where the body post holes now go. Share this post Link to post Share on other sites
bindarrian 6 Posted September 1, 2016 I put the 49400 body up against the GT2 from the TA02SW and the wheel arches match up pretty much exactly. Don't think there will be a problem with the wheelbase Share this post Link to post Share on other sites
mastino 1085 Posted September 9, 2016 ...purchased. (preorder on Tamico). 1 Share this post Link to post Share on other sites
firefoxussr 482 Posted September 9, 2016 On 9/1/2016 at 7:01 AM, bindarrian said: I put the 49400 body up against the GT2 from the TA02SW and the wheel arches match up pretty much exactly. Don't think there will be a problem with the wheelbase I thought there was a way to get to 230mm, like by reversing standard TA02 arms. Someone check me on that, I don't have a standard TA02 rear arm set. Share this post Link to post Share on other sites
ChrisRx718 4470 Posted September 9, 2016 3 hours ago, firefoxussr said: I thought there was a way to get to 230mm, like by reversing standard TA02 arms. Someone check me on that, I don't have a standard TA02 rear arm set. That is how you get the 236mm wheelbase to suit the GT2 body, by flipping the rear arms so they point towards the front of the chassis rather than swept backwards (257mm wheelbase). 6mm doesn't sound like a lot, but I can't see how you could hide that much difference. The TA02 is already configured with some Toe-in, so it already appears shorter than the 236mm it's designed for, as I understand others have studied the manual and found no difference in the mechanical parts from the 911 GT2. Share this post Link to post Share on other sites
firefoxussr 482 Posted September 9, 2016 55 minutes ago, ChrisRx718 said: That is how you get the 236mm wheelbase to suit the GT2 body, by flipping the rear arms so they point towards the front of the chassis rather than swept backwards (257mm wheelbase). 6mm doesn't sound like a lot, but I can't see how you could hide that much difference. The TA02 is already configured with some Toe-in, so it already appears shorter than the 236mm it's designed for, as I understand others have studied the manual and found no difference in the mechanical parts from the 911 GT2. Nahh, the TA02SW uses TA01 arms flipped. That's the 236mm.http://www.tamiyaclub.com/forum/index.php?/topic/71146-wheelbase-shortening/&do=findComment&comment=508824 this is post is what i read about TA02 with the standard TA02 arms flipped results in 230mm:http://www.rctech.net/forum/12508413-post6.html What I wonder is if the arm would collide with the motor in its suspension travel. Someone with a standard TA02 should try flipping the arms for us all to see! Share this post Link to post Share on other sites
Truck Norris 2237 Posted September 10, 2016 49400 body on the 84399 GT2 TA-02SW chassis. Riding a bit high as the body's just resting on the posts. With the backs like this: The fronts look like this: Share this post Link to post Share on other sites
njmlondon 570 Posted September 10, 2016 Thanks for the photos TN. It looks like the 6mm difference is all in the front wheel-arch then. Will the wheels rub? Share this post Link to post Share on other sites
Truck Norris 2237 Posted September 10, 2016 That's not the actual kit, it's my GT2 chassis with a spare 934 body. Just a demo of how far out the wheelbase is. The 84431's body mounting holes are in a different place to the 49400 30th 934 so I don't know how they've positioned them. It may be that both the front and rear are a little off. We won't know until someone's built and photo'd one. Share this post Link to post Share on other sites
ChrisRx718 4470 Posted September 10, 2016 TC has a showroom NIB entry already, together with a photograph of the box clearly showing a 236mm wheelbase. Curiouser and curiouser! Share this post Link to post Share on other sites
marcod13 79 Posted September 11, 2016 They have arrived in Canada! Just picked one up but don't think I will be opening it very soon. This kit was part of a 4 unit pre-order. Three of them were gobbled up when preorders began back in June or so. And when the store recieved shiment, I was fortunate enough to be the one to grab it before someone else could lol! Alas they will be getting more in from what I undestand, so everyone can have their fun I'm curious if there is any special packaging on the inside. I doubt it tho (because i heard some parts rattling about) but would've been nice to be released like the style of the 49400, 30th Anni. 3 Share this post Link to post Share on other sites
pininfarina 1009 Posted September 13, 2016 it also landed here in Asia as well. Share this post Link to post Share on other sites
khyzersoze 268 Posted September 13, 2016 How limited is this kit supposed to be? What is the going price in USD for this kit in HK? Also, anyone know the part number for light buckets that I can use with this body? Share this post Link to post Share on other sites
djmcnz 754 Posted September 13, 2016 I can't even find a place to pre-order them. Grrr. Share this post Link to post Share on other sites
novaris 2 Posted September 17, 2016 (edited) oops/ sorry.. Edited September 17, 2016 by novaris new info Share this post Link to post Share on other sites
mastino 1085 Posted September 17, 2016 Tamico just yesterday confirm me that the 84431 kit arrive in Germany as scheduled. At the end of next week my porsche will be sent to my home. Share this post Link to post Share on other sites
Shodog 1835 Posted September 19, 2016 I have one on order with Tower Hobbies but came across one on eBay today so I hit the BIN button quickly. Got an email today, 9/20 that I should get it on Saturday at the latest 1 Share this post Link to post Share on other sites
volvotech 101 Posted September 20, 2016 I imagine the first batch of these is going to sell out rather quickly. Tower still says "end of September". Any day now... Share this post Link to post Share on other sites
khyzersoze 268 Posted September 20, 2016 I've got one hopefully coming to me from Tower as well. 1 Share this post Link to post Share on other sites
volvotech 101 Posted September 20, 2016 Got an email from my bank, my CC has been billed. Checked the order status: Preparing shipment from Reno, NV! Share this post Link to post Share on other sites
khyzersoze 268 Posted September 20, 2016 8 minutes ago, volvotech said: Got an email from my bank, my CC has been billed. Checked the order status: Preparing shipment from Reno, NV! Lucky! Mine still says waiting. Share this post Link to post Share on other sites
Shodog 1835 Posted September 21, 2016 Testing out some colors. this is a three stage paint process. On the lexan its translucent red, then gold then gun metal. Opposite for the front of the willy body. Just seeing if the wing will match I painted this Porsche Carrera body a couple of months ago when I heard about this release. It's a clear red backed with gun metal. 2 Share this post Link to post Share on other sites
Dojo Dave 889 Posted September 21, 2016 I cancelled my tower order, in exchange for a Tamico order. Not in any rush. Share this post Link to post Share on other sites
salvine 125 Posted September 21, 2016 Got my Tower shipping notice last night Share this post Link to post Share on other sites
Shodog 1835 Posted September 21, 2016 3 hours ago, salvine said: Got my Tower shipping notice last night I didn't get the e-mail but apparently the one I ordered from tower is out for delivery today and I should be getting number 2 I ordered from eBay tomorrow. Share this post Link to post Share on other sites
