Wanted: Damaged Striker Chassis
Hello:
I have a lead on some plastic sheet; a tube of putty; some O.R.V. parts, and a morally-questionably idea... Now it seems I require a damaged Striker/Sonic Fighter lower body and/or a Striker upper body.
The reason I specify a damaged shell is because the Striker typically breaks near the front suspension, and I have no intention of using the stock parts.
Hence, if you have any broken tubs (the less repairable, the better), please let me know! Thank you :)
I am still on the lookout for a damaged Striker chassis per above. Even an intact one with a scruffy finish is acceptable as well...
Not bad, but the Canadian dollar is weaker than the pound - that will add up quickly to way more than I care to spend. Thanks, though! I may keep tabs on it regardless.
