bullitt
My Wild One re-release
Over the years, I have loved this hobby tremendously. Like all of us, I have hit roadblocks in the past and hit a major one this spring. I decided to call it quits and let everything go. After talking to a friend about it, his words of "you have to keep at least one" put a little thought in my head. I started thinking that yes, everything is going, but maybe getting or keeping one RC wouldn't be a bad idea. It would have to be cool enough that would sit on my bench and look cool may get run a couple days a year. A few weeks later, Chris with REC came out with the wide front wheels for the vintage buggies and the wheels started turning. I decided to get a Wild One. My brother had one and I always thought it was cool, but I never had one of my own. I am going to kick it old school and just have fun with it and not get so stressed out over making it scale. Stickers, paint, aluminum wheels, and maybe some lights is what made buggies rock in the 80s and that is what I am going to do again. Bring back the fun in my RC life.
I had just sold off my Willys & Wraith as well as a few other parts and had me in a spot where I have not ever been in a while...stocked with cash. My first purchase was a standard set of REC's wheels and a pair of front wide wheels, the WO, a pair of 915s & Sand Scorcher paddles, bearings, light buckets, and shims.
The fed ex driver showed up yesterday morning and I got busy. I had some uninterrupted time and within 30 minutes, I had the chassis painted.
757F481C-EE73-42FF-99A6-44CE62CC0CE5_zps
690B9C55-36EC-47E4-90B0-1C45390F5199_zps
After a little while, progress was being made. I had some RC4WD coil overs and I thought I would give them a try and with a spacer up top, they work just fine.
AC52DA3B-66D4-4719-9BE0-13A4B232D4F7_zps
FD7E1CE1-84D2-4E91-BEB8-111B646379B5_zps
8EDC6870-E454-4C4D-8ECE-EC572D6A1565_zps
9E94D89A-8707-4BAB-9B9B-DE487B3F5146_zps
I wanted to run some lights on it had still had my Tamiya light controller and I think it's all going to fit. I think. I'll have a couple pairs of 5mm LEDs up front and pair of 3mm in the back.
B41E3F9A-E362-4F7F-94EB-49877FC67B6C_zps
7AA3CB76-772D-46FC-8B4E-89A968693D27_zps
I even got the panels painted tonight as well. The driver was painted on the outside for a matte finish.
553F2E6B-E8E7-41B3-90A0-99F9CA80BC5E_zps
3D2E7A14-6833-4F57-9B46-01630843DF87_zps
That's all for now.
Harry
I decided to slow it down a bit because this build was going to be coming to an end quicker than I hoped. I moved the electronics around several times and I think I finally found my happy spot where everything can be reached easily. I also put the stripes on the body and other than a Tamiya sticker, these will be the only re-re stickers going on the buggy.
B2035466-17D1-4A32-A2B1-A6AE8ADD47A4_zps
Harry
I got the rear lights mounted after looking and looking for the best spot. It's not exactly what or how I wanted, but it's clean. If I mount a spare, it's going to block them.
C86FBAC1-12A9-4CB3-A307-0A665DD1644D_zps
Everything is all wired and sitting in place.
7A628A3C-4BC0-4260-9CA0-91C4E1747FAB_zps
Now it's time to put the rest of the decals on and paint the front "tubing" red to match the rest of the tube work.
7448423D-F84E-4469-ADC8-15FAB972FA3B_zps
91679384-1249-450E-A8E6-C1BA8EF6CDCF_zps
89493677-FE9B-4019-9C41-28E319D3EB91_zps
6A840D3A-0C63-4C58-9AC5-9885A5100357_zps
That's all for tonight.
Harry
I was lured back up into the attic last night and did a little more work on the buggy. My rear hex adapters came in and I mounted up the rear wheels. I like these a lot!
FCFC5E2D-3CED-4093-8509-79821F36EC5C_zps
D70BEA99-C977-4F1E-99F4-4A6ADAB15F9A_zps
I am just waiting for the F103GT parts tree to come in. The spindles were set up so Tamiya could use sedan wheels on the F1 chassis (F40, NSX, and another kit) that has the 850 bearings in the spindles and the shaft runs right through the spindle. The shaft is offset of the cross pin, so I will have to hold the spindle with screws.
4344941B-38FA-4523-9361-771FCF57CE16_zps
Hopefully the parts tree comes in today so I can confirm if it will work. If it does, then I can keep these Rogue wheels and have another set for the Wild One.
I hooked up a battery pack and was pleased, but then decided I may need a couple more lights.
B3E4E350-8E20-4A6A-8CBF-0B0FC7CEEA0C_zps
E9915FCB-F3B2-4D91-8933-13FBF5D56585_zps
Then I added some stickers and took more pictures.
F504DDFF-6E68-4418-BBA9-1F59CD74AC66_zps
7C320862-FBA8-482E-B55F-4355393FC72F_zps
Thanks for looking.
Harry
I took the WO to work today and let it spin the tires in the vacant building. Before long, it was catching air on the slope near the loading dock :) After not having a buggy since 1990, I really forgot just how much fun they were. I shouldn't be allowed to have fun like this at my age.
D24B4AB4-861C-4DE5-BBE3-286D68C87823_zps
B8A0BC2C-2E6D-4673-89B0-55092E928805_zps
82063DC2-96C0-4E63-908C-385D9DA9358E_zps
I decided to have another run before I left the office and try to set up a better camera angle. Dang it this buggy is fun! I can't wait to get it on some dirt!
6C2348D1-5F5A-47B3-96C6-585F81A4E0DD_zps
C57ECC96-6AA9-4B23-83DE-2CECD94512C2_zps
4F6F2FCC-2DE2-4313-B686-F919DD5AA496_zps
605D63E3-1DC5-4628-8D95-97F62BB15209_zps
42BA1C3D-18C3-41FC-A5AA-1D0306B2BBF1_zps
Harry
  • Like 10
Looks like your having loads of fun ! Well done the car looks great. You make me want to get a wild one now ...
I finally received the the last of parts I ordered from Japan! I wasted no time putting it together as well. The parts tree is forms a Tamiya F103GT.
AB31E052-7D00-4544-91EA-D578216DE825_zps
I had to cut them down to fit inside the A arm which took all of 5 minutes.
1E366D31-3C67-42F5-9F33-042F57824E58_zps
They are a little wobbly, so I either need to make a sleeve for the screw or drill & tap for a set screw to keep the original spindle shaft.
8EA1AC2A-0F8E-41E9-9FB4-C8E451460FF2_zps
The finished result. I think these are a touch too big.
01519133-F3E8-41FD-8DCE-787FC9BCF71E_zps
Ahhhh! Much better! These look just right!
FA8844A2-C2B2-44A5-8AF2-8B7748D37EF3_zps
07911264-C76D-4A6E-B0E7-B04D4F76F73F_zps
3155A1C2-0F56-4CAC-89EE-E6E4B34CEB7A_zps
CEDD3EF7-814D-4ACE-9D87-43417B621A01_zps
Thanks for looking!
Harry
Ha Ha! I am not going to narrow the aluminum wheels. They are too pretty to cut! I ordered two sets of aluminum wheels and I will have the option to run the 915s or sand scorcher rears, and 915s or rough rider fronts. This buggy will have more bling than a rapper.
Harry
I kind of thought that, but just in case. The narrowed mud thrashers would look really nice though.
Harry
7 hours ago, bullitt said:
They are RC4WD 80mm dual spring shocks from a Gelande II kit. They are just right for the WO. It would be nice to find a stiffer set of springs, but for the little bit of driving I will do, they should be fine.
Here are the king versons
http://store.rc4wd.com/King-Off-Road-Scale-Dual-Spring-Shocks-80mm_p_2498.html
Harry
Awesome, thanks
It's been a while, but I finally got some additional upgrades and got around to painting the helmet and details.
I bought 2 sets of Rogue Element wheels. I am starting to wish I had bought another set of narrow for up front.
E3E9A4D9-BCB8-472D-A967-05767BDA81CC_zps
C79D8BD0-C6F9-4C33-861E-C9D616BD0E2C_zps
F8C13818-4D23-4C9D-9CBE-CF2AF45268D8_zps
623DCFEA-3B8F-4F95-971D-A205F632FE49_zps
308CC38F-E878-4BC6-A8D0-313D7732F8FB_zps
A8F9542D-DB0C-4DD0-8293-E39AF07C9E49_zps
9898F890-F600-4B0B-A8A9-4DDDAE6E8A54_zps
Harry
These fronts with either rear looks good to me :) I've never understood Brat fronts on a buggy :huh:;)
Maybe it's an American thing, I don't know. I actually do like the smaller fronts and would love to have the small tires all the way around. Since we are playing the what if game, I would like the fronts to be the same height as the rears.
HArry
I finally painted my driver and decided he needed a little protection. I know he's not on a dirt bike, but I always felt this helmet needed a visor to protect from rocks and such.
7EB4296C-B432-4892-8F8A-3CC7AFC98DC9_zps
40C2D122-95AC-4D20-8C77-92A88D2DF286_zps
Then a little more paint, some stripes, and finally some goggles.
D22AA9AC-4E64-423B-8074-2EC405BC9D45_zps
D94CA1D0-9B5D-4AB4-9BD3-B42C5261C985_zps
6BEEC53D-D507-4E88-BAE7-ABD9F3E7A3B7_zps
F4F10863-89A4-4F37-B2F9-D6D56D6AD0DE_zps
To make this old school buggy more old school, I put in my last AM radio and now have it all dialed in. Now, where's that dirt?
Harry
