Hello Peeps,
Last night I completed my NIB Clod, I wont say it was a pleasure to build, but it was good to see it complete.
Upon taking it out for a run I noticed that if I turn the left or right whilst the car is stationary, the car moves forward or backward slightly, like there is some sort of interference, or something, can anyone suggest why this might be happening? (it is the original MSC).
Also, the ESC that comes with the T or E-Maxx, the Novak cyclone 14.4, is it any good? I have heard that the Novak Super-rooster is the one to use, but just wondered what it was like as a comparison, what motors limit does it have.
Si.
Both are on sale at Tower for $120...
EVX is sold by Traxxas, not Novak:-
SPECS: Input Voltage: 12 cells (14.4V)
Case Width: 1.75"
Case Depth: 2.17"
Case Height: .085"
Weight: 3.5 ounces
Motor Limit: 19 Turns minimum
On-Resistance: (F).006 ohms ®.006 ohms
Rated Current: (F)160 amps ®160 amps
Braking Current: 320 amps
Continous Current: 30 amps
Reverse Delay: Zero Seconds
BEC Voltage: 5 Volts
BEC Current: 1.5 amps
Power Wire: 14G/ 9"
Input Harness: 26G/ 9"
Switch Harness: 26G/ 6"
Transistor Type: Hyperfet III
PWM Frequency: 1000 Hertz
Protection: Thermal Shutdownid="size1">
Super Rooster:-
SPECS: Voltage input: 6 to 10 cells (7.2-12V) On-resistance: .002 Ohms
BEC voltage: 6.0v/3Amps Weight: 4 OZ
Maximum current: (forward) 320 amps (reverse) 160 amps
Case size: 1.63" x 2.02" x 1.22" RX wire length: 10.5"
Batt wire length: 13" Motor wire: 13"
Wire Guage: 14 yellow (+), blue (-)
When using the Super Rooster with dual motors there is a limit to the
ESC'S capacity. Super Rooster can only handle dual motors in parallel
as low as 15-turns. In series the Super Rooster can handle any two
motors. When the motors are in parrallel you count half of the turns
of one motor for the load on the ESC, and when they are in series you
count the total number of turns.
Novak recommends that users stick with 15-turn motors in parallel,
while any wind in series will be safe.id="size1">
Does the car move when turning to lessen the strain on the steering components.
It takes MUCH less force to turn the wheels if they are rolling than if they are stationary, therefore putting less pressure on the steering joints.
Maybe the set-up ( design ) of the chassis is to encourage this movement for the above reason.
That makes sense, I suppose that could explain it, although I'd have thought if that was the case it might mention it in the manual.
Do any other clod/big trucks do this?
I used the super rooster with great results. Everybody i know who has one chucked their evx in favour of it! I never had an evx because it was a second hand maxx with a brand new super rooster as the evx got fried by the last owner.
I think its the super rooster for me.....when i get some cash!
I have also managed to sort out the problem of the moving car, I followed voltars advice and swithced crystals and it worked.....weird, especially as these crystals are fine in other cars????
Si.
