TwistedxSlayer 1290 Posted September 3, 2016 Morning guys and girls. As many are aware Tamiya never made a buggy based on the TB-01 Chassis, they did how ever make a truggy based on it (but i wasnt aware of that before i decided to undertake this project). Plan. Take my TB01, add some wide arms, taller shock tower on the rear, throw on some suspension and see what happens. Whilst trying to use only Tamiya parts. The actual outcome. 1st job. Find a set of suspension arms that will fit. After some advice from XVPilot on arm widths, i decided the cheapest option was to go for TL-01B arms. But rather than buy just the arms. I bought a complete doner vehicle and stripped it for all the bits. Pics will follow and ill update throughout the day. 2 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted September 4, 2016 Alot of the build was trail and error. The rear was built 1st but im lacking pictures of rear build. The lower arms went straight on. As did the drive shafts. The issue came when trying to fit the upper control arms. The TL-01B were too short. So i thought id raid my parts box and found TT-02B ones fit quite nicely. The next issue for the rear was the shock tower. But that gets sorted later. Share this post Link to post Share on other sites
TurnipJF 9192 Posted September 9, 2016 An interesting idea. I take it you chose this approach due to the ruggedness of the TB-01 drivetrain? 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted September 9, 2016 Its a tough chassis and the only one i had. Lol. And i love the chassis, ive had a tb-01 in some form since 2001 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted September 10, 2016 Right, rear shock tower. Along with owning Tamiyas I also have a Hobao Hyper 10TT Brushless - awesome truck. It came with several spares, so i thought i'd raid them to see if i could find a suitable shock tower.... and yes i could. Quick test fitting, lines up perfectly. Now to address the rear shockers. DT-02 Shocks with several spacers, and an TT-02B GPM steering link to space them away from the shock tower. The control arms are TT-02B GPM And they covered the front and rear, and the steering. The next issue i had was with the steering. Using the GPM arms, they caught on the upper chassis plate. So i spaced it upwards to give clearance. Which takes us to this point.... 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted September 10, 2016 (edited) As its a buggy, it needs a wing. This issue has taken me several hours to figure out, but today I managed it with a massively over engineered wing. The wing mounts are standard TL-01B ones that mount on sideways to the TL-01B, my issue is i needed to turn the mounts through 90degrees. So several attempted and screws later, with the help of some suspension ball joints.... To me, this has been a great little project. The front camber issue has been cured *for the moment* by removing the front drive shafts and cups and making it RWD. The turning circle is awful, but its fun. This is currently how it stands, Other than a couple of minor issues, its finished! The body will be a Neo Scorcher one, and it will be velcro'd to the chassis. Edited September 10, 2016 by TwistedxSlayer Photobucket Links 3 Share this post Link to post Share on other sites
Terz1 745 Posted September 11, 2016 Great little project there. I didn't go as far as you did in transforming an on road vehicle to an off road vehicle but I did a similar thing with my TL01B buggy regarding fitting larger shocks. The TL01B was based on a road car and I felt it had dampers which were too short so I found some taller aluminium shock towers and fit these to the chassis which allowed me to fit what I think are proper, large buggy sized shocks. Have fun with it. I'm sure you will. 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted September 11, 2016 Its currently my only '2wd' vehicle and im having alot of fun with it. Ill be able to get the velcro for the body tomorrow and give it a run out with the body fitted. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted November 1, 2018 @ThunderDragonCy Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted November 1, 2018 @TwistedxSlayer Thanks! 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted April 25, 2020 Scrolling back through some old threads and posts, I think @svenb needs to see this Share this post Link to post Share on other sites
svenb 3778 Posted April 27, 2020 On 4/25/2020 at 5:51 PM, TwistedxSlayer said: Scrolling back through some old threads and posts, I think @svenb needs to see this Thanks Been on here a few years and never spotted this👍 Can't work out if your a on or off road bloke🤔😅 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted April 28, 2020 8 hours ago, svenb said: Thanks Been on here a few years and never spotted this👍 Can't work out if your a on or off road bloke🤔😅 Still trying to work that out myself. Lol Share this post Link to post Share on other sites
wifflebat 3 Posted February 2, 2021 Lockdown has had me poking through boxes in the garage and I've come across my TB-01 Arai Impreza that I never really took to as I was more into buggies. The question is...can I easily upgrade it to something like this (I don't have many parts kicking about) or just sell it and buy a cheap buggy. Money and time would be the two determining factors. Time I don't mind so much but I'l rather not be faffing about with trial and error. Can I just buy Levant bits?? Are there any other similar projects anyone could recommend? The only other I found is linked below from the same member! Thanks in advance for any light shedding! Thank Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted February 2, 2021 40 minutes ago, wifflebat said: Lockdown has had me poking through boxes in the garage and I've come across my TB-01 Arai Impreza that I never really took to as I was more into buggies. The question is...can I easily upgrade it to something like this (I don't have many parts kicking about) or just sell it and buy a cheap buggy. Money and time would be the two determining factors. Time I don't mind so much but I'l rather not be faffing about with trial and error. Can I just buy Levant bits?? Are there any other similar projects anyone could recommend? The only other I found is linked below from the same member! Thanks in advance for any light shedding! Thank Hi mate. Converting to a buggy isn't the best idea. Converting to a levant is a good idea but it is costly. The parts aren't the cheapest. I'd suggest selling the Arai Impreza if the body is good and its boxed it should mostly fund buying a buggy. Buggy wise.... the world is your oyster with anything from toy grade cheap and cheerful to high end expensive. Share this post Link to post Share on other sites
wifflebat 3 Posted February 2, 2021 Thanks. I'm waiting for the great ebay 99p fee purge anyway so I'll lump it on when that comes around again. Now I've just to research the cheap buggy/truggy selection...a lot has changed since the days of the Hornet and Mardave Meteors! 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted February 3, 2021 10 hours ago, wifflebat said: Thanks. I'm waiting for the great ebay 99p fee purge anyway so I'll lump it on when that comes around again. Now I've just to research the cheap buggy/truggy selection...a lot has changed since the days of the Hornet and Mardave Meteors! Can always try putting it up for sale on here Share this post Link to post Share on other sites
wifflebat 3 Posted February 7, 2021 This is it here http://rover.ebay.com/rover/1/710-53481-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=164690818548&ipn=psmain&icep_vectorid=229508&kwid=902099&mtid=824&kw=lg&toolid=11111 I'll have a look and see if I can find how to share in the for sale section 🤔 1 Share this post Link to post Share on other sites
