khyzersoze 268 Posted September 4, 2016 Always wanted a Lunch Box when I was younger, and I finally got one. For being my cheapest kit... I've seemed to have spent the most on it. Crazy thing is that I'm contemplating getting another one later on! Anyway here it is. Still deciding what decals, extra paint work I want to do to the body, but this is pretty much it. As it stands right now With lights on! FX10 Mod Uncompressed.... Compressed... Used a suspension arm piece from a WT-01N kit to mount the bottom of the shock. (I bought the longer WT-01 arms so I didn't use these) Electronics Hobbywing Justock XR10 ESC, Speed Passion v3 13.5T Brushless, Sanwa RX-371W Receiver, Savox 254mg steering servo, Generic lighting kit Chassis Stiffening Upper shock tower brace Rear deck brace Lower rear shock brace Forgot to add that it's also got a full ball bearing kit. 12 1 Share this post Link to post Share on other sites
Terz1 745 Posted September 4, 2016 Very nice lunchbox. Really tastefully done. It looks great just as it is so take your time deciding on any more paint or decals you're going to add to it. Look forward to see what you do with it next. Share this post Link to post Share on other sites
mongoose1983 3335 Posted September 4, 2016 Nice monster van AND shocks. By the way, what are those? Share this post Link to post Share on other sites
khyzersoze 268 Posted September 4, 2016 1 hour ago, mongoose1983 said: Nice monster van AND shocks. By the way, what are those? I believe they were the 100mm GPM dampers. I got them from RCMart - http://www.rcmart.com/dp100sv-alloy-ball-damper-100mm-with-12mm-coil-spring-p-62965.html?cPath=389_390 Share this post Link to post Share on other sites
mongoose1983 3335 Posted September 4, 2016 Thanks! By the way, have you checked this bit? TCer Pintopower designed a special axle bracket for these vans that I think you're going to love. Here's a link to his store (and the explanation video): http://www.shapeways.com/product/G72GAY3NL/tamiya-cw01-lunchbox-pumpkin-montero-unimog-trans?optionId=59473027 Thanks again for the info on the shocks, good stuff. Share this post Link to post Share on other sites
Problemchild 2149 Posted September 4, 2016 stunning - good work JJ Share this post Link to post Share on other sites
Davy Crockett 137 Posted September 4, 2016 Very very nice! Had a lunchbox, sold it and still regret it hope to do another one day good work! Share this post Link to post Share on other sites
Nitomor 2122 Posted September 5, 2016 All the right mods really well executed. I resisted the FX10 mod but seeing those 2 pics it really shows just how effective it must be. Nice one Share this post Link to post Share on other sites
khyzersoze 268 Posted September 5, 2016 On 9/4/2016 at 10:33 PM, mongoose1983 said: Thanks! By the way, have you checked this bit? TCer Pintopower designed a special axle bracket for these vans that I think you're going to love. Here's a link to his store (and the explanation video): http://www.shapeways.com/product/G72GAY3NL/tamiya-cw01-lunchbox-pumpkin-montero-unimog-trans?optionId=59473027 Thanks again for the info on the shocks, good stuff. Thanks for the link! I might look into his front arms instead of another FX10 arm kit if I get another Lunch Box. Regarding the rear axle... I did look into the rear 3rd shock mod, which Pintopower seems to have come up with an alternate solution using that axle bracket. I was initially planning to do it, but then I decided that I actually didn't need it. Some of the issues were I guess slapping noise from all the torque under acceleration and having that axle tilt back the way it's designed and that some people were experiencing the motor hitting the rear shock when this axle tilt happened. If you look closely at my aftermarket rear lower shock mount/brace, you'll notice that there are multiple positioning holes for the mounting of the rear shocks. I mounted it the furthest away from the axle, so the motor hitting the shocks under acceleration isn't an issue with mine. I haven't really paid any attention to any slapping noise, but if it does bother me... it shouldn't be hard to customize it so that it's got some sort of rubber bumpers in that part of the suspension. All in all, I still have some things I want to do before I call this one done so that I can move onto the next kit. 1. Get a better wheelie bar 2. Finish up minor paint applications to clean up some areas and give some more detail. 3. I figured out what I want to do as far as decals go.... Stay tuned! 1 Share this post Link to post Share on other sites
emory70 153 Posted November 22, 2016 One of the better looking boxes I've seen in a while. I have one I started to get crazy on, doing lots of mods. And never finished it. So I've got another in trying to be more chill about. Share this post Link to post Share on other sites
Daveyb 40 Posted November 22, 2016 This is really nice!! Great job with the lunch box!! Share this post Link to post Share on other sites
howaboutme 247 Posted November 22, 2016 Great job! Excellent pictures, nice and crisp. Share this post Link to post Share on other sites
Black Van Dan. 56 Posted December 7, 2016 Really nicely done. Love it!! 😎 Can you shed some light on the WT-01 pieces you used to mount the shocks to the lower wishbones please?! Also where did you get the alloy rear shock mounts with the brace bar. I'm struggling to track those down. Cheers, Dan. Share this post Link to post Share on other sites
khyzersoze 268 Posted December 7, 2016 I bought rear shock mount from sicnmeproducts off ebay - http://www.ebay.com/usr/sicnmeproducts The WT-01 Pieces are either C3 or C4 from the WT-01N kit. It's from the narrow chassis version Amarok. I have decal designs ready, just need to print them when I have time. Will post pix when I do. 2 Share this post Link to post Share on other sites
Black Van Dan. 56 Posted December 8, 2016 23 hours ago, khyzersoze said: I bought rear shock mount from sicnmeproducts off ebay - http://www.ebay.com/usr/sicnmeproducts The WT-01 Pieces are either C3 or C4 from the WT-01N kit. It's from the narrow chassis version Amarok. I have decal designs ready, just need to print them when I have time. Will post pix when I do. Thanks for that. Have you run it yet? Interested to know what it goes like as I've gone for a 12 turn. 👍🏻 Share this post Link to post Share on other sites
khyzersoze 268 Posted December 9, 2016 2 hours ago, Black Van Dan. said: Thanks for that. Have you run it yet? Interested to know what it goes like as I've gone for a 12 turn. 👍🏻 Yes, I've run it. Pretty quick, but you have to ease into the speed. Punching full throttle right away will make the truck wheelie and tumble in a bad way. I need to get a better wheelie bar, since the kit one is tiny and doesn't really prevent the truck from tumbling with the 13.5t brushless in there. One of these days I'll get around to doing a video. 1 Share this post Link to post Share on other sites
neverfollow 599 Posted December 9, 2016 Gorgeous LB, great job! Share this post Link to post Share on other sites
Black Van Dan. 56 Posted December 9, 2016 18 hours ago, khyzersoze said: Yes, I've run it. Pretty quick, but you have to ease into the speed. Punching full throttle right away will make the truck wheelie and tumble in a bad way. I hope you didn't damage that lovely body shell? 🙈 Share this post Link to post Share on other sites
Terz1 745 Posted December 9, 2016 Are you going to still run this shell when finished or get a lexan one? It would be ashame to damage this after the time and effort you've out into it. I'm getting a lunch box this Christmas. I'll be doing the shell completely box art for the shelf and I'd like to find a place that that do a lexan lunch box shell to take the knocks. I'll do this one a different style I think. Saying that. Does anyone know where they do a lexan lunch box shell?? Share this post Link to post Share on other sites
Black Van Dan. 56 Posted December 9, 2016 Oops double post sorry 😊 1 Share this post Link to post Share on other sites
Black Van Dan. 56 Posted December 9, 2016 53 minutes ago, Terz1 said: Saying that. Does anyone know where they do a lexan lunch box shell?? http://www.hobbystores.co.uk/default.asp?WPG=HOB_HomePage1&PageNumber=1&s=c:0,c:130,b:Parma 1 Share this post Link to post Share on other sites
Supercoolnothing 721 Posted December 9, 2016 Thanks for the link Black Van I've got an email alert set up for when they get the shell back in stock. The fact that I don't want to wreck my plastic shell's the main reason that I'm not really running my lunchie. Share this post Link to post Share on other sites
khyzersoze 268 Posted December 9, 2016 3 hours ago, Black Van Dan. said: I hope you didn't damage that lovely body shell? 🙈 Well, just before this paintjob, the shell was military green. I scraped up the black paint on that back chrome bumper, and a little of the roof rack. Luckily the plastic shell itself didn't get damaged at all. That's how I know the truck will wheelie and tumble with this amount of power in it! I then decided that a silver paint job would look better anyway, and I re-painted the chrome bumper that I painted black. I don't know if I will get a lexan shell. It's fun to run, but I only really damaged it to that extent because I drove it on asphalt. I kind of know how to control it now so we'll see. Problem is... I'm quickly growing a collection of cars that make it hard to figure out which to drive! Share this post Link to post Share on other sites
Terz1 745 Posted December 10, 2016 3 hours ago, Black Van Dan. said: http://www.hobbystores.co.uk/default.asp?WPG=HOB_HomePage1&PageNumber=1&s=c:0,c:130,b:Parma Thanks for the link . I was going to say thanks that link was 'Vantastic' but it was too corny . It looks a well detailed lexan shell. It will do nicely. 1 Share this post Link to post Share on other sites
trexfan 56 Posted December 14, 2018 On 9/4/2016 at 12:27 PM, khyzersoze said: Always wanted a Lunch Box when I was younger, and I finally got one. For being my cheapest kit... I've seemed to have spent the most on it. Crazy thing is that I'm contemplating getting another one later on! Anyway here it is. Still deciding what decals, extra paint work I want to do to the body, but this is pretty much it. As it stands right now With lights on! FX10 Mod Uncompressed.... Compressed... Used a suspension arm piece from a WT-01N kit to mount the bottom of the shock. (I bought the longer WT-01 arms so I didn't use these) Electronics Hobbywing Justock XR10 ESC, Speed Passion v3 13.5T Brushless, Sanwa RX-371W Receiver, Savox 254mg steering servo, Generic lighting kit Chassis Stiffening Upper shock tower brace Rear deck brace Lower rear shock brace Forgot to add that it's also got a full ball bearing kit. hi .where did you get the shocks from if you dont mind me asking Share this post Link to post Share on other sites
