Sign in to follow this
InsaneJim69
F/S Tamiya Big Bore Aeration Dampers
I have for sale a full set of 2x front and 2x rear Tamiya Buggy Aeration Big bore Dampers, 54504 +54505. Comes with full spring set. All dampers are almost immaculate with only very very minor marring to the top caps where the plastic nut attaches.
14468261_1505580056122740_86987430628428[/img]
Any questions feel free to ask.
£50 posted within the uk, or overseas at extra cost.
James
Nice, do you know what the length is eye to eye on both sets?
Nito
Hi, sorry for the late reply. The fronts are 75mm from centre of top eyelet to the centre of the bottom eyelet. And the rears are 93mm. You can make then slightly longer if needed by replacing the lower ball cup with a longer one. Or make them shorter by adding an internal spacer if needed. It states "for use with TRF5** series, TRF201, DB01, DB02 and may fit other models"
Forgot to mention that small pieces of hardware are also included, basically what both sets came with when new.
James
