31 minutes ago, MadInventor said:
That's good value for money, only trouble is I will need to a 4S LiPo to it as well.
Managed to get mine a bit cheaper too (Not by much)
Finding a place to fit all those cells is going to be the problem 😁
Speed Run Entry
HCT
3900KV BrushlessĀ
3s Lipo
20t Pinion (Stock Gears)
35kph/21.7mphĀ
(Speed run halfway through this Video)
Had loads of fun with this today, although it's got a few battle scars now! I guess the low gearing is keeping the speed down, acceleration is ridiculous, even with the ESC on 'Soft'. Ā I might try my 120a ESC, the 45a one has not given me decent results in any of my cars. Although i'll only do it for a speed run, this thing needs no more speedĀ :lol:
Ā
I just made an order to Amain for some 48P spur gears and matching pinions. I have decided to dedicate my TT02 chassis for speed runs. I am going to run NiMh just to see what I can achieve, and then move on to LiPo. Does this sound like an interesting idea or have I had too much to drink?Ā :wacko:
Crack on!
Be good to see the difference tbh.
Finally got around to running my blitzer beetle again managed 80.1 kmh 49.77 mph. Don't think there is any more in it with its current motor combo.
2520kv trackstar motor and esc
3s 2200mah turnigy
the big pinion for the blitzer 19t? can't remember
Ā
12 hours ago, MadInventor said:
At least it outran the bullhead :ph34r:. Are we running 1 car per person for the silver can list, or can we have multiple entries ? If so, can you add my Jugg2 entry at 22kph on page 11 (It's already in the 4wd list).
Also, I think this is going to be a popular category, so can we make it a top 20 plz ?
Even it will be popular it will be good to see lots of new cars being entered ( across the Tamiya range) so you can enter more than one car.. going to enter your Jugg2 now, ignore my PM to you I found it ;)
Just checking, silver can doesn't include torque tuned does it? Just that a lot of kits come with torque tuned these days.
I need one of those 1060 escs and a 3s, reckon the Novafox will give it a good nudge
No I don't think so Jonathon... theĀ Torque Tuned and Sport Tuned are supposedly faster than silver cans ( many discussions on whether they are or aren't according to no of turns) so to keep it simple... just silver cans.
Note to all entrants Ā - Do not peel off the Torque Tuned sticker to make it look like a regular old silver canl.... I'll be watching... not sure how to check it but I'll be watching lol.
This will be the staple diet of many I think... go grab a set!
Be interesting to see what the speed difference is between them!
I gave Ā£12 each for mine delivered, well worth an investment, soĀ much so, I've now got 3! šŸ˜€
Where do you find them? Ebay have a few, banggood have them and so does RCMart, are they known for being copied and having a lot of fakes out there?
I suspect some silver cans will be faster than torque tuned, who knows whats inside that silver can without a sticker to tell you?Ā
Not a clue about fakes, more than likely!Ā
http://m.ebay.co.uk/itm/232146217771?_mwBanner=1
I think it's the detail that's going to make it interesting, finding a good one.Ā I'm guessing with it being cheap mass produced, some are more closer to blueprint than others!Ā
Jason...
You put my HCT in the Silver Can list... it's brushless RWD ;)Ā
Ā
Not sure I've said it in the past, but good work on keeping the ever changing list current! Must take up quite a bit of your Forum timeĀ B)
Ā
2 hours ago, Jason1145 said:
Fastest Silver can is 59KPH as of today!
36.6MphĀ is 58.9KmhĀ :lol:
Silver Can entry,
Tamiya TB04 Evo IV
36.8Mph - 59.2Kmh
Castle Sidewinder 3
3S Lipo
48dp, 64t Spur/ 40t Pinion
Tamiya Rubber Tyres
@Phil_HĀ .2MphĀ :DĀ  No smoke from my motor just a toasty smell :)
Ā
I ran the 418Ā today but just some gentle test pulls to get some log data as IĀ was worried about motor temps. Ā The logs lookĀ good and it drives lovely soĀ IĀ plan top go back out on Tuesday and give it hammering :)Ā
I did have an awesome few runs with my FF03Ā and set a new front wheel drive and 2s record. Chuffed to bits as IĀ never thought it would go so fast when IĀ started working on it, it could be the fastestĀ FF03 in the worldĀ :ph34r:Ā  Anyway...
FWD Speed Run Entry
FF03
82Mph - 131.9Kmh
Hobbywing v3.1 120 Amp
Hobbywing 3.5T Motor
2s LipoĀ :DĀ (7500 Mah 90c)
48dp, Spur 60t - 41t Pinion
Contact Foam Tyres
Ā
Ā
54 minutes ago, El Dougo said:
Ā
Ā
it's actually .2kph as I ran 59kph...
I'll wait for some wind before my next run :)Ā
Good work...and the FF03!Ā :o
Ā
What is your current setup include?
3520kv turnigy motor/esc 2200mah 3s running the big pinion 19t?? can't remember exactly. Its getting pretty hairy at that speed.
Ā
Ā
the sunshineĀ :(Ā  Ā It look's like it's going well! Ā
Add the details to your video postĀ it shouldĀ be eligible for an entry. Would moveĀ you toĀ tenth place overallĀ B)
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. Ā Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      DougĀ
      Ā
      Ā
      · 0 replies
    • WhteRbt
      Checking out this status thing…  And now with a beautiful avatar! šŸ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
