What is your comment between both cars??
I used to own both at different time frame, so never compare side by side. Rumour has it that the rear suspension of Boomerang is different than the Hotshot, so which part of rear suspension has been revised on the Boomerang? the bottom or upper rear arm is different than HotShot??
Correct. The Boomerang's rear arms are different than the Hot Shot's. Basically, Boomerang arms allow room for dampers to be mounted ahead of the arms. The Hot Shot lacked this clearance as it was originally a rear monoshock/cantilever design. When the Hot Shot arms were re-used in the Super Shot, Tamiya had to mount the dampers behind the rear arms as they had no clearance to mount them ahead like the Boomerang eventually would.
