kontemax
WANTED TR-15T Parts (also for Dyna Storm/Dyna Blaster)
Hi mates,
I need these parts for my TR-15T project:
From Adjuster Bag
- Front Stabilizer bar BF7 (common wiyh Dyna Blaster)
- Rear Stabilizer bar BF6
- Gray 6mm Adjuster BF1 - 1 piece (common wiyh Dyna Storm) Found
From Press Part Bag
- Front Reinforcing Plate BP3 - 1 piece (common wiyh Dyna Blaster) Found
- Gearbox Sub Plate BP4 - 1 piece No more needed
From screw bag B
- 3x44 mm, gearbox long screw BB4 - 1 piece (common wiyh Dyna Blaster and Dyna Storm) Found
- 3x21 mm, Tapping screws BB6 - 2 pieces (common wiyh Dyna Blaster and Dyna Storm) Found
From Screw Bag E
- 2x20 mm, Cap Screw BE1 - 1 piece (common wiyh Dyna Blaster and Dyna Storm) Found
From ball connector bag
- Damper mount BJ4 - 2 pieces Found
From Avante/Egress
Avante/Egress 25 mm chassis columns - 4 pieces (common with Astute) Found
The parts can be used but the important thing is that they will be not too much ruined.
Max
Max, i may have several of the parts listed above. If you don't mind me taking a couple of days checking out my stash - i will get back to you.
Dominique
I have a new A and B screw set on the way for Dyna Storm but I'm taking some screws out for my super astute rebuild so I'll have some screws left over when I'm done. The long ones I definitely don't need.
Please let me check the content of these screw bags.
Max
Only two more items needed to complete the project.
Max
I believe that the solution will be this one if I will not find them.
Max
