The Top Force bodyset doesn't fit directly the Manta Ray for two reasons:
- Manta Ray doesn't have the center bodymount
- Manta Ray antenna holder rubs the Top Force body
- Probably also the sides of the Manta Ray chassis rubs the Top Force body.
Solutions:
- Create a your own center body mount.
- Cut the antenna holder and replace with an alloy one directly bolted in the bathtub.
- Not sure about the chassis sides, probably they don't touch the Top Force body.
Max
They do fit quite snugly, use velcro at the front end and as Maxx said I think you have to file down the aerial holder.
Here's one I made earlier. :)
I can't quite see in the photo's but did you make your own centre body mount ?
I used a top force body on my Ray with only a front body mount screw placed in the front gearbox brace. ( Pic has no front pin in but that's where it is)
Looks great with no other problems
