I had one of these guys back in 03, and let it go. Now I have another, and I'm trying to remedy a situation I had with the last one. The rear axles are too short to use with HPI 2.2 rims, by just a touch. The WW hubs are kinda long, and don't fit the rims quite right. The hubs that come with the HPIs are shallow, and narrow the track too much. Is there another rear axle that's just a bit longer than the WW unit? A while back, someone here gave me a lead, but they're the same exact axle.
  • 3 months later...
Òr u could try putting a little rubber seal in the shaft from any left over from your shocks when you built them up ,you know those little black seals you use in your shocks just use one of those on each side see how you go worked for me for my ww2 when i fitted a yeah racing control arms kit but shafts were a little short so tried this trick ..😊
