Which type are you looking for?
There are two types of 6V connector:
The 4000Mah Bruiser/Hilux battery connector. Tamiya X9118. This is very similar to the standard Tamiya Connector, but with one plug rotated 90 degrees.
Can't find any on-line now. Took me a while to find one a while back.
There's also the older 6V connector for the regular sized pack. A smaller plug. Tamiya 50039.
One here: http://www.ebay.com/itm/Tamiya-50039-Battery-Connector-Set-6V-Hotshot-Astute-Bigwig-Fox-934-935-MRC-/351932707737?hash=item51f0d2f399:g:ZckAAOSwwbdWNBRm
Another one: http://www.ebay.com/itm/Vintage-Tamiya-39-Battery-Connector-set-6V-5039-/281586492731?hash=item418fdce53b:g:yQQAAOSwk5FUz~2g
Check before ordering as those connector sets are for the old scorcher type oblong 6V - 1200 MAH battery , to be correct you need the larger one for the chunky 6v 4000 MAH , see top of page 11 in the Blazer and page 15 in the Blazer manual for alternative battery options . Bruiser manual pages 14 - battery deck installation  and page 16- installing battery ( note the battery and speed controller fittings ) also note the extra info on alternative battery type installation options on the LH side of page 16 . I've got one of the larger speedo fittings for the 4000v battery and they are a lot bigger than the standard 7.2 and 6v fittings
