This post is meant to be for information and is not intended to say one differential is better than another. The facts are easy since Thorp is long out of business and their products are hard to find and when you do find them....very expensive.
  THORP 4550 BALL DIFF MIP SUPER BALL DIFF
THRUST WASHERS 24.90mm (0.980") O.D.                                             X        14.46mm (0.569") I.D.                                                              X        0.8mm (0.031") TK  27.11mm (1.067") O.D.                                             X        18.35mm (0.722") I.D.                                                              X        0.91mm (0.036") TK
DIFF GEAR 38.55mm (1.517") O.D.                                             X        9.68mm (0.381") I.D.                                                              X        7.53mm (0.296") TK  39.66mm (1.561") O.D.                                             X        8.00mm (0.315") I.D.                                                              X        7.51mm (0.295") TK
No. OF TEETH 47 48
PEAK TO PEAK 2.73mm (0.107") 2.82mm (0.111")
DIFF BALLS 3.16mm (0.125") diameter  2.49mm (0.098") diameter
No. OF DIFF BALLS 12 14
THRUST BALL LOAD BELLEVILLE WASHERS X 4 COIL SPRING
THRUST BALLS 1.58mm (0.062") diameter 2.00mm (0.078") diameter
No. OF THRUST BALLS 8 5
When we were discussing the MIP Diff during development, I made some notes during one of my Frog Jumper tranny rebuilds...
Sorry to hi-jack your thread.  Just thought I could add to the Knowledge Base...
Terry
Blackfoot Counter: 52T outer, 17T inner
Blackfoot Diff: 48T
Frog Counter 01: 49T outer, 18T inner
Frog Counter 02: 50T
Frog Counter 03: 52T
Frog Diff: 47T
Thorp Counter: 52T outer, 18T inner
Thorp Diff: 47T
The Blackfoot Counter, the Frog Counter 03, and the Thorp Counter are all 52T and are the same diameter. The Frog 50T is slightly smaller, with the 49T being smaller still... The 18T Frog and the Thorp Counter inner gears are the same diameter. The 17T BF inner is slightly smaller...
The 47T Frog and the Thorp Diff are the same diameter, and the 48T BF is slightly larger.
The Frog and BF gears are the same thickness, and the Thorp are slightly thicker.
Yeah, the Thorp diff was designed for the Frog / Hotshot (and others that share the same diff) while the new MIP diff was designed only for the BF and MB.
It is possible to use the BF counter in the Frog with the MIP diff, understanding that the gear ratio will be different from stock (will be slower).
If MIP releases a 47T diff then it would be a drop-in replacement for the stock gear diff for the Frog.   Not sure if MIP has plans to do so.
