moffman 5707 Posted August 16, 2017 11 hours ago, TeaMonster said: It is a gorgeous looking buggy. Can you tell me how you found the masking for the paint? I had some bleed on the red to yellow. I do like the silver on your as well👍 I used normal tamiya masking tape ( Which I find works really well) then on the leading edge I use tamiya tape for curves item number 87178! 3 or 5mm it's brilliant I find it sticks really well and it more pliable and I've never had bleeds! 1 Share this post Link to post Share on other sites
TeaMonster 506 Posted August 17, 2017 9 hours ago, moffman said: I used normal tamiya masking tape ( Which I find works really well) then on the leading edge I use tamiya tape for curves item number 87178! 3 or 5mm it's brilliant I find it sticks really well and it more pliable and I've never had bleeds! Cheers mate, I will get some of the 871 tape on order and give it a go. Share this post Link to post Share on other sites
scoobybooster 245 Posted August 17, 2017 On 16.08.2017 at 1:25 PM, MAD RACER said: Mine went together quite well. This is a pure racing machine from the 80's and just like the RC10. Yokomo & PB these kits needed a lot of hand finishing and fine adjustments during the build. Having said that the CAT RE re is a lot easier to build with today's tools and Schumacher's excellent fit. Just very different in it's design in some area's which is what made it a world class racing machine . The right screwdriver for the pozi screws is a must I feel. The soldering of the ball joints on the sway bar was super easy. The material used took to the solder very easy . I just scratched the surfaces to be soldered with a X Acto blade.. Not to mention also the improvement of the manual. Original 80's manual of the CAT was nothing but a joke 1 Share this post Link to post Share on other sites
Hobbimaster 190 Posted August 17, 2017 Is the drive train "open", or sealed on the cat? I'm trying to decide if I want to endure another build, but ultimately where I run its very sandy and a "open" style transmission does not last long. Share this post Link to post Share on other sites
scoobybooster 245 Posted August 17, 2017 3 hours ago, Hobbimaster said: Is the drive train "open", or sealed on the cat? I'm trying to decide if I want to endure another build, but ultimately where I run its very sandy and a "open" style transmission does not last long. Judging from the names abbreviation Competition All Terrain, this should include also running it on sandy tracks. The drive train is protected with lexan belt covers and undertray, the body covers the upside of the car quite nicely. So this shouild not be a big issue. Share this post Link to post Share on other sites
Hobbimaster 190 Posted August 17, 2017 Thank you scoobybooster! Looks like I will be adding a cat to the collection. Share this post Link to post Share on other sites
Robert5000 928 Posted August 20, 2017 For those of you that have completed step 7, is this supposed to be flush? In that the metalthingy isn't suppose to be visible? I've done and redone this over and over again now but the metal washer is visible every single time. Am I (as usual) doing something wrong, or is this how it should look? Share this post Link to post Share on other sites
MAD RACER 566 Posted August 21, 2017 Ummm Cant recall mine like that. Are the belt fences the right way round? The pulleys the right way around? Just a guessing here....... 1 Share this post Link to post Share on other sites
Robert5000 928 Posted August 24, 2017 On 8/21/2017 at 9:39 PM, MAD RACER said: Ummm Cant recall mine like that. Are the belt fences the right way round? The pulleys the right way around? Just a guessing here....... I thought so, but it certainly doesn't look like that way. Thanks for confirming my suspicions! I'll have to give it another go. Maybe screaming at it will help. 2 Share this post Link to post Share on other sites
Lhodgo 208 Posted August 28, 2017 Mine arrived, metro hobbies came through. Any consensus on a nice brushed motor? I want it to run but mainly shelf. Kinda want the vintage feel. Not lipo / brushless. 1 Share this post Link to post Share on other sites
Baja500 93 Posted August 28, 2017 23 minutes ago, Lhodgo said: Mine arrived, metro hobbies came through. Any consensus on a nice brushed motor? I want it to run but mainly shelf. Kinda want the vintage feel. Not lipo / brushless. 👍 Mine is arriving tomorrow from metro, i didn't opt for the upgraded heavy duty tranny, as im only going to be running a tamiya 540 as metro specified i should use for that vintage feel with a gentle run to look after it. But im open to other suggestions..? Share this post Link to post Share on other sites
moffman 5707 Posted August 28, 2017 3 hours ago, Lhodgo said: Mine arrived, metro hobbies came through. Any consensus on a nice brushed motor? I want it to run but mainly shelf. Kinda want the vintage feel. Not lipo / brushless. I've put a old team orion 11turn double in mine like you I didn't want to go brushless etc I've had it for ages it has quite a bit of punch I tried brushless but all it did was make the diffs make a very unpleasant clicking sound! Suppose that's why you can get a heavy duty transmission?, The problem I'm having at the moment is rubbish steering I mean like sand Scorcher bad! Share this post Link to post Share on other sites
Lhodgo 208 Posted August 29, 2017 Nice, only up to step 5 in my build. No steering issue yet😬😬 did Schumacher align with a motor company back in the day? Share this post Link to post Share on other sites
TeaMonster 506 Posted August 29, 2017 This car had a hpi motor in, but inthink that was driver only sponsorship and not Schumacher Share this post Link to post Share on other sites
Snappy1 964 Posted August 30, 2017 moffman, what esc are you going to run with that little beast? Share this post Link to post Share on other sites
Lhodgo 208 Posted August 30, 2017 Strange question in know, but is there super glue in the kit, says there is but I don't seem to have any. Makes my decision not to buy some when I was staring at it in the market tonight quite annoying! 1 Share this post Link to post Share on other sites
Robert5000 928 Posted August 30, 2017 I haven't emptied the kit in search for super glue, but I didn't see any either so I just bought a tube. @Lhodgo 1 Share this post Link to post Share on other sites
moffman 5707 Posted August 30, 2017 11 hours ago, Robert5000 said: I haven't emptied the kit in search for super glue, but I didn't see any either so I just bought a tube. @Lhodgo Don't bother there isn't any! Like I've said before this kit is a patients user! Share this post Link to post Share on other sites
StueyS 41 Posted August 31, 2017 It doesn't come with any, but I would recommend a medium viscosity one so it does not run everywhere! Share this post Link to post Share on other sites
Lhodgo 208 Posted September 1, 2017 Wow, this build...its definitely different. Was anyone else disappointed with the finish of the lexan rear wing or did I just get a dud? There was no protective film and it's quite bubbly. In fact if looks like it's been cooked in the microwave! The mask lifted and I got super bleed from the black paint. Waiting for a bottle of this magic tamiya paint remover everyone bangs on about. Hopefully that will clean it up. Share this post Link to post Share on other sites
SuperChamp82 743 Posted September 2, 2017 Ok guys - the kit + upgraded transmission just arrived ! I'vd read everyone's thoughts above but are there any other build tips to note before having some fun ? Also what essential hop ups should I source / why ? Finally, what ESC and motors are you running with the upgraded transmission ? Share this post Link to post Share on other sites
Peter_B 997 Posted September 2, 2017 Out of interest, what is included with the upgraded transmission? Share this post Link to post Share on other sites
tamiya3speed 461 Posted September 2, 2017 20 minutes ago, Peter_B said: Out of interest, what is included with the upgraded transmission? Have a look at the details here: http://www.racing-cars.com/pp/New_Cars_and_Parts/CAT_XLS_Masami/U7236.html Share this post Link to post Share on other sites
Peter_B 997 Posted September 2, 2017 15 minutes ago, tamiya3speed said: Have a look at the details here: http://www.racing-cars.com/pp/New_Cars_and_Parts/CAT_XLS_Masami/U7236.html Thanks. Am wondering if it will drop into my Procat. Share this post Link to post Share on other sites
Avante2001R 305 Posted September 6, 2017 Wasn't expecting a CAT but as the second Boomerang kit was no where to be seen I changed my order to this: Share this post Link to post Share on other sites
