After rebuilding my original 84 Hornet I've decided to tackle a second new Hornet build applying all that I learned from the first build. I'm sure I'll still make some mistakes and learn more throughout this build.
Your suggestions are welcomed and needed!
It's like Christmas morning!
That TEU-104 isn't going in this build. I put it into the first Hornet build. This build will have a TBLE-02s.
While waiting for more transmission gears and parts, I think I'll get started on some paint.
Turned the bathtub into a paint studio. I'm sure setting something outside would be better but I'm in a loft and this is easier. The fumes are contained in the bathroom with the fan running. No need for a cheap headache high from polycarbonate paint!
1 hour ago, RcMadness74 said:
Wow, looking great, love those wheels and white paint. What are you going to run for a motor?
I'm pretty sure I'm going to put in the Tamiya RZ Super Stock 23T.
The electrics should be fine - any ESC with a motor rating of 23T or lower can handle it, and not likely to melt a battery connector - but the Hornet is already reasonably fast with a stock 540 motor, or at least "sufficiently interesting" in handling. The car is rather light, so a 23T motor should give it a good turn of speed.
To the point, the motor will run with a Ni-MH battery without problems; I used such a combination without issue.
Although the super  stock RZ is a 23t motor it can hit 30,000 rpm & has a load of torque. It's one of my favourite brushed motors.
I took it back out of my wild one as it was too much.
Might have to add some weight to the hornet front end to aid in better handling.
