hi all
anyone else had problems settting up these teu101bk esc before?
downloaded the setup manual,followed to the setup description,no matter what i do,it dont work,just keeps flashing/blinking
im very near to setup with big hammer!
thanks nic tt
When you mean keeps flashing... does it change at all?
Is the motor connected? Because it uses the motor as a speaker, you can't hear the "bip..bip..bip" if no motor is connected... :P ... the "bip..bip..bip" tells you the RX is unresponsive, not outputting any signal.
If RX is on failsafe mode (alive but no TX signal received), it still outputs a signal and ESC won't  "bip..bip..bip".
not to worry,acoms handset im using,think it knarkard,,flashes are the same no matter what i do,when motor is connected it just bleeps constantly
on the look out now for new esc
thanks for reply :D
has it worked before in the past? :)
check that RX says "BEC"... some modern RX goes dormant if it gets too high voltage from ESC (101 has no BEC)... so it just plays dead rather than going up in smoke.
Could try running RX off 4xAA battery box if you've still got it.
some times they work,,and they dont,,,,,yes hammer time! had less fuss with cheap and nasties esc,,must be old tamiya esc that have the problems,,got 2 others the same that work perfect just this one dont wonner play ball
I would still check the Tx and Rx before threatening it with a hammer!
if its beeping , that says to me that its working, just not getting a signal to work with....
Or...get a Quicrun 1060 for about 18 quid.... BUT if the radio is knackered, you still wont have a "working" ESC!
