FunwithFox
Kumamon figure size?
Hello!
Could someone with access to a Kumamon kit measure the figure dimensions (without hat) and
the mount to which the bear is fixed and secured with tape (see picture below).
Bear height/width?
Head size?
Arm length?
Back to pedal paw dimension (without tail)?
Mount width, lenght and height?
Thank you in advance
FunwithFox
Edited by FunwithFox
typo
Total height including base - around 4 inches (100mm)
Total width - around 2 inches (50mm)
Base length - 2.5 inches (63mm) Figure is about this long as well, but "set back" on the base around 12mm
Base width - 1.5 inches (38mm)
Head is around 1.5 inches wide (38mm), arms are about the same length.
Hope this helps.
