ThunderDragonCy 7882 Posted May 21, 2017 42 minutes ago, ALEXKYRIAK said: Thunder, what's the black wheel in top left of this photo? Cheers Schumacher 12mm hex rear. It's what I got for running my RT1 street tyres on http://www.racing-cars.com/pp/Product_Category/Wheels_Tyres_and_Inserts/U4365.html Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 23, 2017 Been running the car for a couple of weeks now and I think I've found my setup. Someone mentioned the other day that it's a bit hard to figure out where I am with this because I've changed so many things, so in a rather *******-about way I'll do a kit list for the setup I have settled on. Note I run 3300 NiMH batteries and an ABS shell, so pretty heavy. If you're running Lipos and the Lexan shell you'll probably need softer suspension. This was last night after checking out the final change and running the truck wheels for the first time in a while. VERY broken and battered body will be replaced by the Mad Bull shell I cut and painted a few weeks back when MCI deliver my decals. So, the build is: Racing Fighter kit which included the Sport Tuned Motor and CVAs Upgraded Kimborough Servo Saver Drivetrain: Sold the Sport Tuned straight away and got a Speed Passion 13.5R MMM Brushless running on the TBLE-02S ESC. 17t steel pinion Geared diff with 300,000 cst diff oil filled about half-2/3 full Full bearing set. 53056 Metal hexes are the rear (only got these are changing wheels all the time started to deform the kit plastic ones. I wouldn't say you need metal straight away) Suspension: Upgraded CVAs with red seals, 54043 piston rods rear 50601 front to use plastic pistons on CVA sprues. 53927 DF03 Setting Spring Set Associated 30wt and 40wt oil 54561 DT03 Anti Roll Bar 9804206 Ball Connector Nuts to replace Step Screw on shock top mounts 50591 Ball Collars for bottom shock mounts to replace step screws (some filing needed on fronts) Cut bridge kit plastic front shock mounts to allow my body to fit. GPM DT03 Aluminium front shock uprights GPM DT03 Aluminium front wishbone lower mount GPM DT02/3 Aluminium front C Hubs 54395 Suspension shafts for outboard front wishbone pivots 53479 Suspension shafts for the 25.3mm shafts to do the king pin pivot in the c-hub/steering upright After a lot of playing around I use the following setup: 3 hole pistons front and rear 30wt oil rear, 40wt front DF03 soft black springs front, gold medium spring rear Low setting front, high setting rear Front soft red anti-roll bar I run a lot on loose gravel so it's more tuned to this. The front ARB helps give some grip and stability to the rear, and the stiff diff oil really helped traction and allows using the soft front springs again. I found I just need the ride height at the rear with this setup. It's pretty soft at the rear for traction and does still bottom out a bit, so I run it a little higher. Running high at the front just gives bad handling. The aluminium parts are mainly because I needed to stiffen up the cut shock bridge and shipping was so ruinous I bought extra GPM parts each time. The C-hubs are known weak points although I never broke my plastic ones. All the suspension shafts were added piecemeal as I started seeing screwpins backing out during extended running. I wouldn't bother straight away unless you're racing. Wait to see what comes loose. 54572 Turnbuckle Set (I actually got the DT02 thinking it was the same - it wasn't! The steering arms don't fit so bought GPM ones) 9805551 Metal Driveshafts 9804237 Metal shaft outdrives (also work for universals) 50823 Hub end cups for metal shafts 54565 Servo Mount (Adds some weight and stiffness to the front, but can't say I think it's completely necessary) 54566 Gearbox Bridge (seems to help strengthen the rear end) Weights for front end. I have 40 grams stashed around the servo and body mount. http://www.ebay.co.uk/itm/FREEPOST-1-x-STRIP-READY-CUT-COATED-SELF-ADHESIVE-WHEEL-BALANCE-WEIGHTS-5g-10g-/152275966078?hash=item23745ad87e:g:-D0AAOSwo4pYl55r Carbon gearshafts (no idea whether it's worth it, but they're cool!) The metal driveshafts or universals are a must if you ask me. The plastic kit shafts catch and bind on the suspension and the metal shafts just allow more droop and easier rear suspension movement. Turnbuckle kit I'm not so sure. I still have the rear installed, but I got annoyed with constantly chasing camber on the front, and put the kit wishbones back on. Not only are they much stiffer (noticeable with the truck wheels), but they also have a fair amount of neg camber dialed in, so I'm happy enough. Wheels: Three sets of wheels in the end.... Kit wheels with Schumacher Cat Block Yellow front and rear with medium inserts. They're supposed to be for 2" wheels, but they work great on gravel and grass. Schumacher 12mm hex rear black wheel and Tamiya bearing black dish front wheels with Schumacher RT1 Green front and rear tyres with medium inserts. Great for street running for not wearing out buggy tyres and green compound is not too grippy so you can still power slide and muck about with the car. Tried B30 and they're just far too sticky!! Blitzer Beetle orange truck wheels 9335134, which required Blitzer uprights 0445207 and 0445169 to replace the kit ones. I ran up some plastic spacers to use buggy wheels on these uprights too. I use Schumacher 1/10 truck tyres, Stagger Rib Yellow Front and Vee4 Yellow Rear with inserts. The suspension setup works with all of these different wheels, and the truck wheels are loads of fun with a bit more clearance and grip. So there we go. My Grasshopper (DT0)3! 5 Share this post Link to post Share on other sites
ALEXKYRIAK 1046 Posted May 23, 2017 Monumental post! Thanks, great reading and very informative. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 23, 2017 Thanks. Glad you liked. Feels good to get the final thing written down! Share this post Link to post Share on other sites
ALEXKYRIAK 1046 Posted May 23, 2017 I was actually just thinking the other day of asking you for a summary of where you're at! There's a load of information here and wanted to make sure I had followed it correctly. 1 Share this post Link to post Share on other sites
mman2005 443 Posted May 24, 2017 Great info Thunder!! 1 Share this post Link to post Share on other sites
ALEXKYRIAK 1046 Posted May 27, 2017 Thunder, did you consider adding the DT-02 ball differential set (53863)? Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 27, 2017 15 minutes ago, ALEXKYRIAK said: Thunder, did you consider adding the DT-02 ball differential set (53863)? Considered it, but never had a ball diff before and most things I read about them involved tearing them down every 5 packs to clean and rear grease them. Couldn't be doing with that and 300,000 cst diff oil is about 15% of the price of a ball diff! Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 27, 2017 I'm open to being disabused of my perception of ball diffs needing lots of maintenance. Feel free to chip in! Share this post Link to post Share on other sites
TurnipJF 9192 Posted May 27, 2017 Nah, you're quite correct re. ball diff maintenance. The diff in my F103 wants cleaning and rebuilding after every second race meet or so, which equates to six packs. A ball diff in an enclosed gearbox would probably be willing to go for longer between rebuilds, but it would still require more maintenance than a gear diff. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 29, 2017 Finally got the time and weather to finish off the replacement shell for the now completely broken original GH2 shell. You can see posts on the mods further up the thread. In summary it's a cut and drilled Mad Bull shell. My original decal idea hasn't worked out and I didn't like the greenish colour the fluoro "yellow" came out so I re-primed in white and sprayed Halfords car paint neon blue. MCI for stock hopper2 decal design in orange/black. Got it clearcoat education last night so going to wait a week for that to firm up before running it. 4 Share this post Link to post Share on other sites
gizard 133 Posted May 29, 2017 Hi First post - been a long time lurker! I am considering a DT-03 Aqroshot with a view to trying to fit a Blitzer Beetle body with similar size tyres and this build thread is very helpful! I would consider nearly all the upgrades that have been applied to the chassis - I also really like the Grasshopper 2 body shell on this (used to have a Grasshopper as a boy). Does anyone have a Blitzer Beetle Shell and a DT-03 chassis to hand to see if the longer chassis looks alright? - I have decided against a full Blitzer Beetle build as the chassis and drive train imo are not as good as the DT-03. Edited to add - I assume you could swap the arms over to reduce wheelbase - not sure what this will do to handling. Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 29, 2017 Hi. Glad you found the thread useful. No idea about the blitzer body, but I do know flipping the arms lengths the wheelbase, not the other way around. Share this post Link to post Share on other sites
gizard 133 Posted May 29, 2017 11 minutes ago, ThunderDragonCy said: Hi. Glad you found the thread useful. No idea about the blitzer body, but I do know flipping the arms lengths the wheelbase, not the other way around. I was thinking of the rear arms - but that might cause issues with the drive shaft length - and also put more weight to the rear - more realistic for a beetle ! Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted May 29, 2017 Yeah that would do weird things to the car. Might get driveshafts to work with universals Share this post Link to post Share on other sites
ALEXKYRIAK 1046 Posted May 29, 2017 Liking the new bodyshell Thunder. Nice. (Might have to give MCI a go also, they look very interesting for custom body schemes. I currently can't decide on a colour scheme for the Racing Fighter I'm building....) 1 Share this post Link to post Share on other sites
sellig 62 Posted May 29, 2017 Blitzer has a 260 mm wheelbase, DT-03 287. I don't think you could do anything reliable to reduce the length at this point. Share this post Link to post Share on other sites
TurnipJF 9192 Posted May 30, 2017 The DT-03 and WR-01 have comparable wheelbases IIRC, so you could get some idea of how it would look by taking a gander at that build thread showing a modern take on the Monster Beetle - I'll see if I can find a link... Share this post Link to post Share on other sites
TurnipJF 9192 Posted May 30, 2017 Can't find the build thread I was thinking of, but a photo of the vehicle (belonging to Terz1) appears in this thread: Share this post Link to post Share on other sites
DaveBuildsRC 210 Posted June 27, 2017 That is one awesome dt03. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted June 28, 2017 12 hours ago, DaveBuildsRC said: That is one awesome ride. Thanks. It's a fun car for sure. Been running it a lot on gravel with the truck wheels recently. Such a hoot. Share this post Link to post Share on other sites
gary1365 90 Posted June 28, 2017 I don't mean to hijack your thread but have you ever had your wheel drive shafts snap. I just snapped my right one. The left one broke a few days ago. Maybe it's just wear and tear. They both broke off flush with hex. It just seems weird. Share this post Link to post Share on other sites
ThunderDragonCy 7882 Posted June 28, 2017 No, never had that on these or my Thunder Dragon (same design). Not sure I run quite such high power in mine though. 13.5t brushless on nimh. I also run in quite big areas where there's not a lot to hit! Share this post Link to post Share on other sites
gary1365 90 Posted June 28, 2017 Both times I haven't hit anything as such. Only a little small kerb like a 1/4 of an inch or less where the surface changes from tar to bricks. Share this post Link to post Share on other sites
gizard 133 Posted July 3, 2017 Righty I have the following arriving soon: Aqroshot DT-03 58610 54561 Anti Roll Bar GPM DT3027 Front Shock tower brackets GPM DT3028 Front Shock Tower GPM DT3008 Suspension Mount front lower GPM DT3055 front bottom wishbone lower GPM DT3019 Front C-Hubs GPM DT3030 Rear Shock Tower GPM DT3056 Rear Lower Wishbone GPM DT3010F Front Wheel hub hex adapter GPM DT3024 Servo Mount GPM DT3010R rear hex adapter GPM DT3022 Rear wheel Hubs GPM DT3160ST Steel Turnbuckles Steering 54628 Steel 17T Pinion 9805551 Metal Driveshafts 50823 Hub end cups for metal shafts 9804237 Metal shaft gearbox outdrives 54566 Gearbox Bridge 54572 DT-03 Turnbuckle Set 9335228 Stadium Thunder neon yellow wheels Speed Passion MMM Series 13.5R BL Motor TARX3 Tamco RC 2.4GHz FHSS 3ch Receiver SAV-SG-0351 Savox Standard Digital Coreless Servo U6503 Schumacher VEE 4 - Blue Truck Tyres U6502 Schumacher VEE 2 Blue Truck U6541 Schumacher Truck 2.2 Foam Tyre Insert (Soft) Already have bearings and will try std suspension to start with..... 1 Share this post Link to post Share on other sites
