Crash Cramer 617 Posted March 22, 2017 I am on the lookout for a few small bits that make the world of difference on the M01 chassis. I need some C parts, namely #7,8,9 if you happen to have some, even used, I would like to hear from you. I am thinking that if they are cracked, I might hold them together with CA glue, so let's see what you have. Also in need of just the idler gear, the smallest one with a 5x8 bearing/bush in each side. I would like that gear to be as near new as I can get as single gears are not all that easy to get. I could just jump in and buy the whole gearbag from eBay UK, but I thought I would ask here first. I have a few bits I could trade with you all. Thanks, Chris Share this post Link to post
Tamiyabigstuff 832 Posted March 22, 2017 How many 7 / 8 / 9 do you need ? I stripped an M01 a while back to rebuild but a cracked chassis means it is now just a bag of spares. Might have the gear - what is the part ref from the manual ? Share this post Link to post
GooneyBird 938 Posted March 22, 2017 From memory are those gears the same in any M-chassis. The diff width is different, but other gears are likely the same size. Share this post Link to post
Mokei Kagaku 2706 Posted March 22, 2017 12 minutes ago, GooneyBird said: From memory are those gears the same in any M-chassis. The diff width is different, but other gears are likely the same size. M03/M04/M05/M06 plastic gears are identical except that they are available in "standard" (White) and "reinforced" (black) versions). M01/M02 gears are different from the others. Have the requested C-parts and gear(s) if interested, and lots of other M01/M02 parts and hop-ups too. Most without original packaging and cut from sprues and put into my M01/M02 parts box, but unused. Also some NIB M01/M02 kits (A110 and Fiat Abarth mostly) and some new built M01/M02 chassises too that I want to get rid of. Share this post Link to post
Crash Cramer 617 Posted March 28, 2017 Guys, sorry the replies were not reported to me "live". Thanks for looking into your boxes of spares and I suppose I need to get my act back together and put your spares to work. I have been a bit distracted of late. PMs coming Share this post Link to post
Mark3gti 151 Posted June 23, 2017 On 22/03/2017 at 0:34 PM, Mokei Kagaku said: M03/M04/M05/M06 plastic gears are identical except that they are available in "standard" (White) and "reinforced" (black) versions). M01/M02 gears are different from the others. Have the requested C-parts and gear(s) if interested, and lots of other M01/M02 parts and hop-ups too. Most without original packaging and cut from sprues and put into my M01/M02 parts box, but unused. Also some NIB M01/M02 kits (A110 and Fiat Abarth mostly) and some new built M01/M02 chassises too that I want to get rid of. Sorry to jump on this but pm'd Share this post Link to post
