Hey all,
I was hoping for some suggestions. I recently picked up a complete Ford Ranger F150 XLT (SRB) that is in great shape. There is just on problem and I think it is a big problem. The passengers side window pillar (the thin piece of plastic that runs north/south) has completely broken off at the top and bottom. I no longer have the piece. My two thoughts: 1. try to fab a new piece and bond it into position. My concern with that option, is that it is just so dang thin. 2. Would be to finish/smooth out the break points and remove the drivers side piece also to match the reworked pass side.
Any thoughts or suggestions would be greatly appreciated. Thanks in advance.
Jay
You might try cutting a thin slice of CD cover plastic - glue that in place with instant clue. Then dremel/use sand paper to finalize the surface. if there are some holes or something, you may use plastic padding to fill in, let dry and dremel/sand again. Then just paint it over and you're done. Takes a little time, but you do not have to break any other body.
Ps. in case the roof window is lost in action, you can cut a new one from the same CD cover - works as a window too (when window has a straight surface).
Thanks for the info. I think I am going to try the thin strip route. The local hobby shop had some similar, that would just be needed to sanded to exact shape. Thanks again!
